No sound deadening on 2019 ES350
No sound deadening on 2019 ES350 / Center Console noise??
I opened the doors and trunk to check the door speaker systems so I can change them and saw zero sound deadening on any metal surface. Is this normal for this model year. I was like wtf, it’s not like it was a cheap vehicle either. Disappointed really.
Anyways, ordered some Kilmat sound deadening material and masked most metal surfaces in trunk and 4 doors. The difference on sound and how the doors close and feel is pretty dramatic.
E46CT (11-07-22)
It's not a matter of sound proofing, but the way they sound when you open and close them.
I did the same thing this weekend with ResoNix CLD Squares and the way the doors open and close makes it feel like a whole new car. It's like closing a bank vault now. It makes it feel super premium.
The following 4 users liked this post by JamesAZ:
OP, you may be mixing up two types of noise. Actual sound deadening cuts road/ambient noise and is mostly (from the factory) layered on the floor, firewall, front and rear bulkhead, roof, and wheel wells. The kind of insulation you put on your trunk for example is really for panel flex/resonance and might affect how a panel sounds when slammed and maybe your car audio. but not much else.
ESh (11-07-22)
I know, the closing would sound much better if they put some of that insulation.
You must know that the 7ES is one of the quietest cars on the road. According to Matt Farah, it is the quitest car he ever driven exept for the full electric or Rolls Royce line.
After this car was tested for the first time, engineers found it to be too quiet so they had to remove some of the insulation. As you can see, the doors does not play a big role when it comes to noise.
After this care was tested, engineers found it to be too quiet so they had to remove some of the insulation. As you can see, the doors does not play a big role when it comes to noise.
https://www.clublexus.com/forums/es-...oor-noise.html
https://www.clublexus.com/forums/es-...new-level.html
If you've ever closed the door of a high-end luxury car, or a car with dampening added on, you'll instantly notice the difference. It's not a "Maybe..." it a "Oh wow!". I did the same treatment to my Camry, and the day I bought my ES I put in my order for the Resonix dampening since I missed that solid door feeling.
F3Woody (01-03-23)
I used to hear the metal shaking from a reasonable sounding music with bass sometimes. All that is gone. Resonance in the car is miles different. If anyone has the time and $60 and have a little couple of hours project I would say go for it. You won’t be disappointed.
Well i was referring to op's thread title: Sound deadening.
Except adding rubber mats to the door improves them in the manner specified by OP by stopping vibration/flexing of the panels. Feel free to visit my post as the first 7ES owner (that i know of) to disassemble the doors and post about adding tiny pieces of mats to control the panel flex. Refer to my post from before where i show pictures.
Also I would caution against just blanket covering a panel. law of diminishing returns at a certain point. manufacturers use 7-figure super computers to figure out exactly where to lay on asphalt sheets for example so they aren't just blanketing cars, wasting money, with no meaningful return. So you may not have access to toyota's secret data but you can sort of guess that maybe the entire panel doesn't need to be covered in 50 lbs of rubber to accomplish a particular / specific task. For me i added a couple tiny pieces on each door and got a nice result with minimal weight. I call it smart targeting. pretty much what car companies do except i use my noggin' for calculations instead of just throwing boxes of mat at my car LOL
The stuff is extremely heavy. Just a tip.
You are not wrong. I definitely used few pieces placed strategically on each metal part. Wasn’t going to waste money and weight to cover every inch. You would be amazed what a 4 inch square piece of kilmat did to a 1.5 ft of metal. So pretty much covering 2 ft of metal would have been pointless.
LexFinally (01-03-23)
So I was just looking at your trunk, and I was planning on using some of my leftovers on the trunk as well, but when I did the same thing on my Camry the trunk had a hard time opening so I had to remove some so it would open again. Are you running into any issues with it? Like is it noticeably slower or louder or anything? Worried about prematurely wearing out the motor if I add too much. Probably will end up adding 2 pounds since that should be enough and not make any noticeable weight difference on the motor.
Not at all, there isn’t that much weight. I know it’s a night time picture but it’s only few pieces to cover the big surfaces. Barely any weight. I also added a piece on the back of the license plate so it solved that problem. However, bottom part of the plate still makes noise when closing the trunk. Need to figure a way so it doesn’t move at all when that action is performed. 4 screws would have solved that issue.
F3Woody (01-03-23)
https://smile.amazon.com/3M-38582-Ex.../dp/B00JR4D70K
That was my line of thought, I don't have a spoiler, so I can't imagine the 2 pounds I'll add will do anything if the motor is designed for the spoiler which I would assume weighs a bit more than 2 pounds.
So I personally don't have that issue on my ES, but on my Camry I did, and if my memory serves me correctly, I added some double-sided 3M tape to it and that did the trick. Think it was this:
