Wheel size
5th Gear
20's are no problem. I have 20x8.5 on mine and they feel fine. gekae24 has 22's on his ES.
https://www.clublexus.com/forums/es-...l#post10487774
5th Gear
I'd think the key statistics here would be width and the tire's outer circumference. A taller wheel and a lower-profile tire that combine to be the same height as stock, if the tire isn't wider than stock, are going to clear the wheelwell just the same as stock.
A lot of online retailers have calculators that will let you know if a certain wheel will fit on your car. You could also use the tire rim calculator on this site https://www.clublexus.com/forums/tir...calculator.php
LexFinally (11-12-22)
