Exclamation point error
drives cars
Could you share a photo of what you're seeing?
drives cars
I think this is what's happening -
Basically, the backup camera has lost its initialization and needs to be re-initialized.
One other possible solution before attempting the full on Service Mode method perfectly
performed in post #9 is to simply run start the car and put it in Reverse. Turn the steering
wheel from Lock to Lock a couple of times, pausing at each extreme for a second.
yep. That is often all is required.
Confusingly, the same exclamation point in diamond symptom is also found in the the " 7-2. Panoramic view monitor" sub-chapter with the same "Likely cause"listed but the only solution listed there is "Have the vehicle inspected by your Lexus dealer."
Curated Content Editor
ES - 6th Gen (2013-2018)
09-26-18 12:27 PM
