FS: Optima Yellow Top Battery D35 (00-01 ES300)
This Optima Yellow Top will definitely fit 00-01 ES300's as confirmed directly by Optima. It probably will also fit ES300's but please confirm on your own. The model number is Yellow Top D35 and here are the specs copied from another site:
810 Cranking Amps 650 Cold Cranking Amps 98 Minute Reserve 48 AH 9.4" Length x 6.7" Width x 7.6" Heigth Approx. 37 lbs.
Notes: Deep Cycle Battery, Standard Auto Posts On Top, Comes with Carrying Strap, Excellent Multi Purpose Battery for Cars and Trucks, Use For Starting and Deep Cycling, Great Choice For Audio/Video Systems, Aux. Lights, Winches, Etc. Durablility is what explains OPTIMA batteries. Last up to two times longer than other batteries!
The item is brand new/sealed and was shipped directly from Optima. Asking for $175 and pick up in New York City is preferred. If you would like it shipped, the item is 37lbs and will s&h would have to be calculated.
Please pm your email address if you would like a picture. Thanks.
Slooooooow
13
01-15-08 11:23 AM
bezeeduzit
SC- 1st Gen (1992-2000)
12
10-13-04 10:08 AM
lightwave76
01-26-03 03:11 AM
