2004 ES330 Program key
Old 10-13-08, 03:53 PM
Ajnabi
Ajnabi's Avatar
Default 2004 ES330 Program key
hello I bought a key from ebay and had the dealer cut it. I am using the instructions below to program it but i am not able to. I got the remote to program but the key won't start the car. Are these instuctions correct for a 2004 ES330?. The key programing instuctions did not work but the remote one did.
Key Programming
1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on brake one time.
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key. If you have a master key then you will probably need to perform this procedure more quickly.
Remote Programming
1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove TWO TIMES.
3. Close and open the drivers door TWO TIMES.
4. Put key into the ignition and remove.
5. Close and open the drivers door two times.
6. Put key into the ignition. Close the drivers door.
7. Turn ignition ON then OFF ONE TIME- this will put the car in ADD mode for your remote. (Turning the ignition ON then OFF TWO TIMES will ADD the remote but will erase all existing remotes.)
8. Remove the key from the ignition. The door locks will cycle one time (or two if you are erasing) . On the REMOTE press and hold the LOCK and the UNLOCK button for 2 seconds. On the REMOTE press the LOCK button for one second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted. IF the locks cycle twice it has failed. IF this happens you must start over. Hold the remotes higher up for better reception
9. Open and close the drivers door. Put key in ignition and pull out. This will end
programming.
Old 10-14-08, 09:14 PM
powerloxs
powerloxs's Avatar
Hi,
I had the same problem. Apparently for the ES330 2004-06 model, you must take your key to the Lexus dealer or a Locksmith that has the software to clone the master key transponder into the new key you bought.
I should add that you can program the remote by yourself.
edro925
01-15-09 03:07 PM
joshoowa
08-23-07 05:56 PM
mikevanle
05-01-07 11:07 PM
whago
05-28-04 03:47 PM
Quick Reply: 2004 ES330 Program key
