Help! Help! need spark plug wire diagram 1998 es300
So, I decided to change my spark plug, fuel filter, valve gasket, and throttle cleaning this week. I finally finished in a hole day it was brutal, and I forgot how the spark plug are wiring. I know that I should have taken one at a time and replaced them as I go along, but I was trying beat the time. Can anyone share some light as to how their 1998 es300 spark plug wire diagram are. There are only three SPW coming from the valve cover to the back that's where I'm lost be'cuz I can't remember which one goes into which from front to back.
Let call the first one from left to right if you're looking from the radiator SPW #1( it's the one that is closer to the serpentine belt) then SPW #2 ,SPW #3( near alternator or battery)
Please help I need this car to start backup so I can get to work on Mon.
I'll be very thank to any one the help me.
Thank you very very much you have save my day.
One more question:
Do I just plug in #1 SPW to #2 SPW and #3 SPW to #4 SPW, and #5 SPW to #6 SPW.
One more question:
Attachment 148331
I have attached a pdf that describes the firing order.
Come peop it has 41 viewer and no reply really need this going. Can someone with the same model please please I begging you just tell me which wire plug into which spark plug #
Here is the diagram that I receive from George_jet
back row:1, 3, 5
front row: 2, 4, 6
All I need is to make sure I'm pluging correctly, here what I've done
1 to 2
3 to 4
5 to 6
back row:1, 3, 5
front row: 2, 4, 6
1 to 2
3 to 4
5 to 6
I've finally fixed my error I got all the spark plug tension wire in order.
My car start right up without any engine shaking has full power, the engine light has gone away as well. I've learn my lesson next time mark and label the tension wires before removed.
My next job is to change the rear strut.
tonychony,
Sorry to get to you late here are the order
Back are: 1 3 5 (firewall)
Front is: 2 4 6 (head light)
Connect 2 to 5
Connect 4 to 1
Connect 6 to 3
Hope this will help you
Connect 2 to 5
Connect 4 to 1
Connect 6 to 3
Move Over Rover
08-10-08 04:53 AM
