Water pooling on floor, rear passenger side.
Old 01-21-10, 02:46 PM
Benjune
Benjune's Avatar
Default Water pooling on floor, rear passenger side.
Hi,
I am new to this website and I thought I would ask this question before I go to the dealership. I have a 1996 ES300 and when it rains hard, I get water pooling on the floor on the rear passenger side. Has this happened to anyone here? If so, how can I fix it?
Thanks
Old 01-21-10, 04:56 PM
ASG14
ASG14's Avatar
It;s either leaking from the main main door seal of the rubber boot (with the door wires) that goes through the B pillar. Check everything for rips or looseness.
Old 01-21-10, 08:46 PM
afang
afang's Avatar
I had a similar problem with my 98 ES300. Mine was caused by a stopped up sun roof drain
Old 01-21-10, 09:08 PM
llcoolpass
llcoolpass's Avatar
afang +1
or leaking window [asg+1]
or leaking seal between front/rear windshield[usually front] and pinchweld [me+1]
the sun roof drains [2] are fairly easy to solve, just careful not to get stuff into the interior during the cleaning. its easy, i say again -- especially if u can use compressed air like a mechanic would have ability to do.
Old 03-18-10, 05:56 PM
tomsole
tomsole's Avatar
Default Leaking sun roof
Thanks everyone for helping me. My sun was leaking and dripping on rear floor and down rear pillar. I found the front drains but could not find the rear ones..I ripped out the trunk carpet and side & rear covering. I found my sun roof drain tube clogged & kinked. Mine was on the left side just after the rear tire (clear soft plastic tube 1/2") went to lowes & replaced it. I also shoved weed wacker cord up to be sure it was clear all the way up to the sun roof. I pored water in the channel. It flowed right out. I will say I did not want to use compressed air as the hose is real soft and I was afraid it would come off and then I would have to remove the head liner. Hope this helps you
Old 05-19-11, 03:02 PM
Baybarea
Baybarea's Avatar
Can someone help me? I have a 97 es300 and found my tube kinked, clogged and completley removed. I want to replace it with a new one but do not know where it is connected from and connected to. Pictures would be much appreciated and hopefull solve this pooling problem. Oh, also does this go the same for both sides as I only found one tube.
Old 05-23-11, 12:34 PM
Baybarea
Baybarea's Avatar
....found my tube kinked, clogged and completley removed. I want to replace it with a new one but do not know where it is connected from and connected to. Could some one post pictures where it is connect from and connected to, I would really appreciate it.
Old 05-28-11, 04:47 PM
Baybarea
Baybarea's Avatar
anyone..................?
Old 06-02-11, 08:28 PM
Baybarea
Baybarea's Avatar
Stananddi
ES - 5th Gen (2007-2012)
07-13-17 05:20 AM
GS350Lexus
08-04-15 03:02 PM
IS300skr
10-27-10 06:36 PM
akfd
GX - 2nd Gen (2010-2023)
06-15-10 06:36 PM
Benjune
Maintenance
01-21-10 08:54 PM
Quick Reply: Water pooling on floor, rear passenger side.
