will a universal o2 sensor fit both downstream/upstream?
just finished replacing my cat after welding and sealing all exhaust leaks, now the car runs so smooth, except just for the p0171 code (which i believe is the afm sensor) so i kinda figured i had to change the downstream sensor cuz it looks beat up n worn also
i have a universal o2 sensor which i originally bought for the bank 1 sensor 2 (by radiator) but found an oem replacement. want to know if there is a difference between downstream and upstream sensor, are there different levels of voltage or heat sensing? i believe it uses same for wires 1-signal 2-ground and other 2 wires are for heated just not so sure on specs
wish my laptop worked cuz i have a usb obd scanner so i can get readings from the sensors
k , i was just told that the universal will fit upstream and downstream as long as it has 4 wires, just would to hear that again as a 2nd opinion to make sure, if not i can get the oem for exact fit and avoid the troubles of trying to fit it which would not be a problem with soldering etc..
where to get access and unplug the downstream sensor is what im trying to figure out? from interior?
You may already be aware of this, but just to save yourself some money, a downstream O2 sensor (after the catalytic converter) is not a vital sensor. It's basically just an emissions requirement that tells the owner if their catalytic converter is working or not. It doesn't tell "tell" the engine's computer to do anything different, whereas an upstream (before the cat converter) is VERY important because the engines computer uses that info to determine the air/fuel ratio.
A downstream O2 sensor's main purpose is for emissions inspection, to just tell the inspector if the catalytic converter is working or not by lighting up a "check" engine light. Earlier OBD 1 cars didn't have this sensor, and many people who "mod" their cars and remove their cats just put a resistor in there so it won't send an error message.
Your car won't run any different as a result of this sensor, so you might even want to just find a cheap used one or solder in a $1.00 resistor and save yourself from using your new $150 O2 sensor.
so would the pre-cat sensors tell u if your car is running lean/rich or would that be the afm sensor or could it be either one cuz i got the p0171
i was also told i needed to reset the sensors, by computer or scanner tool?
This is by far, not the easiest task I've done for this car. Due to working conditions. Difficult, when u don't have a garage and youre working outside so its very cold and snowing, and of course the popo's lol (for welding, but they gave me a break cuz they knew I was grindin'). Could've taken it to the shop to get it welded to save money/time but I wanted to brush up on my welding skills plus to own my very 1st starter welder. Which I know I may need for future projects anyways.
bank 1 senor 1 is by firewall
bank 2 sensor 1 by radiator on header
![](http://i65.photobucket.com/albums/h209/dabaddon/02sensorlocation.gif)
bank 1 sensor 2 after cat
![](http://i65.photobucket.com/albums/h209/dabaddon/OxygenSensor-RearW01331605096BOS.jpg)
PROBLEM SOLVED FOR P0136 which was the o2 bank 1 sensor 2 which I replaced with a universal one. Had to remove driver seat to unplug the connector. then unscrew it from underneath the car. Rewired/soldered it and works like a charm.
Just down to 2 codes, a p0325/p0330 which are knock sensors or wiring. Which I will do on the weekend and pull apart the intake manifold in order to get to it.
Is upstream two oxygen sensors are located on Sensor 1 on Bank 1 and Sensor 1 on Bank 2 and downstream is one oxygen sensor located on Sensor 2 bank 1 after catalytic convertor ?
Also are the two upstream 02 sensors identical ?
I have Bank 1 Sensor 1 error code p0130 coming on my 1997 Lexus ES300. I am confused which one to buy .
I want to buy denso oxygen sensor which is having 2 types of 02 sensors
Model # 234-4622 - for upstream ( 2 required )
Model # 234-4137 - for downstream (1 required)
Please help.
Please help.
I think it goes Bank 1 Sensor 1 is behind the firewall, Bank 1 Sensor 2 is by the Catalytic Converter
Werner05
06-18-17 07:45 PM
