coilovers
if you want a very smooth ride, go with the Tein SS. They a bit more expensive but the comfort is worth it. You could also get the BC coils. I would get them with a 9k front/7k rear spring rates. Only thing with BC coils is you would have to find a way to secure the ABS and brake lines as the brackets that come with it aren't the right ones. I had ksports before and for the price I'd rather go BC and I really don't recommend the ksports.
I have the K-Sport, bought them last year and havent had any issues with them. I bought them from a vendor here on CL and bought them for just under $900.00 dollars. I would think about getting Megan Coilovers and price is reasonable. If I were to buy coilovers now, I would buy the Megan's, better quality and slightly higher price than K-Sport, but like I said, better quality. Just my 2 cents.
not sure about the megans but for the price ksports aren't bad. however, they are mad stiff. They were stiffer than the JIC's I had on my car. I'm usually ok with stiff suspension but the ksports drove me nuts. The Tein SS, JIC, and BC Racing are much more compliant. I daily my car on BC's close to 130 miles a day and have no problems with comfort.
I got BC Coils from CircuitMS. I love them.I think they ride just fine. I'd recommend them. Comforts Great with tune options. Only thing was it didnt come with the tophat so i had to decompress them and take the stock ones. Other than that I love them and once i get skinnier tires, im going lower. [daily driver]
I've been to the site and didn't c the es listed at all.
BC Coils for the Toyota Camry will fit the ES300, they do have a kit made for the ES300, (it can be found on BC Racing's UK website) however be warned this kit does not have upper mounts so you may want to keep that in mind.
the ones i got for the camry fits just fine just get the 94+ model and it comes with pillow ball mounts and the entire deal.
only thing is, if i max out the front, i can only slightly tuck my tires....to go lower, u need a set of shorter springs.
first gen ksport is garbage, none of the shocks last over a year. second gen is just fine but the shocks are overdamping, so the ride is pretty rough. however, ksport offers different lines of products, their higher lines of coilovers are pretty much the best u can get except they cost 2.5k+
I purchased new mounts for my own kit, and its a good thing that I did, as the mounts on the original suspension of my car were pretty much shot.
I also found out that stock mounts also made alignment very easy, the alignment shop I went to, didn't have to do anything at all to my alignment, everything was within spec, the only thing that needed adjusting for me was the rear toe.
