DIY Clean 98 ES300 MAF sensor
Old 06-12-11, 05:02 PM
download
download's Avatar
Default DIY Clean 98 ES300 MAF sensor
Ref to this helpful link:
http://www.lexusownersclub.co.uk/kno...v2&id=152&c=11
It does reduce the rev time from starting the engine.
From 3-4 seconds to 1-2 seconds.
Reduce the big white smoke from starting too.
Hope it will improve the MPG from 21MPG too.
Before cleaning, it was totally black, almost saw nothing wire inside.
Spay directly from the front for a few seconds. Let it dry. Less than 30min job only.
I used Carb Cleaner, CRC cleaner are recommended too.
Old 06-12-11, 05:57 PM
imherenow
imherenow's Avatar
ok so when u start the car in mornings the engine will rev up and stay like that for a minute or two ( in summer @least)..but i have noticed ion my car that when i start the car the needle first stays @ low rmp...like around 1-2 and then within seconds will rev up to the usual 2-3 rmp (eventually coming back to normal ideal rmp)..i dont know why it does that? is it due to battery or this MAF sensor? or maybe i put some LEDs inside (under footwell)??? any idea?
Old 06-12-11, 06:15 PM
download
download's Avatar
In summer time, when the starter move ~1 second @ 1-1500 rpm, once the engine start it will jump a little to ~2500 rpm. But it will drop to ~1200 rpm at once. It is normal for me.
I think the unburnt fuel were collected and exploded to make it jump.
For the first 1-2 mins, it will remain 1000~1200rpm. After it warm up that will drop to ~700rpm.
Did you cleaner the TB/IVAC before?
http://us.lexusownersclub.com/forums...howtopic=30723
Old 06-13-11, 06:40 PM
imherenow
imherenow's Avatar
no i dont think the TB/IVAC was cleaned before ..it now has ~157000 kms on it
Old 06-13-11, 09:24 PM
download
download's Avatar
Buy a can of Carb Cleaner, spray the TB/IVAC & MAF sensor, it does smooth out the idling very much.
Especially it did be not cleaned before.
Old 06-17-11, 04:25 PM
smokesgtp
smokesgtp's Avatar
Even better, CRC makes a MAF sensor aerosol spray available at most auto parts stores. Ive had good results. Smoother idle, cured a slight highway surging issue in the cold as well.
I wouldn't use carb or brake cleaner like many personally..... its a 200$+ part. I wouldnt touch the wires either... Disconnecting the negative battery cable or pulling the ecm fuse for ten or fifteen minutes wouldn't be a bad idea either when your done...
Old 01-29-12, 08:24 PM
MrShim78
MrShim78's Avatar
Thanks to download, great Post...
download, i want to do this for my 1997 es300 too, bought it recently and in the mornings the idle goes to 1.5-1.8k rpm for a good 2-3 minutes before it settles down to under 1... also my mpg is terribly..only 17 mpg
just wondering, did this diy do alot for your mpg?
Old 01-29-12, 11:55 PM
download
download's Avatar
In the mornings the idle is 1200, it settles down to 700 only, quite low.
Mine is 21 mpg and is not very good to me too.
Did you change the plugs? Use syn oil would help a little.
Old 01-30-12, 08:29 AM
MrShim78
MrShim78's Avatar
hi download...
so it seems that cleaning the MAF while it is a good idea and should be done didnt really help ur mpg? 21mpg is sitll way better than my 17 lol. i think my throttle body has never been cleaned too..
by "big white smoke" you meant the excessive water vapour that comes out the back? especially in the cold? i get that alot too...in the cold. above 10C there is no 'white smoke'...
i have not changed the spark plugs yet but that is on my list for this week... i think that may help some as they were last changed about 60,000 miles (95,000 km) ago.
i am thinking high mileage oil , the kind that helps with seals,etc? just because the valve covers are old and i dont want thinner synth to cause oil leaks etc...
Old 01-30-12, 11:49 PM
download
download's Avatar
There are so many things affect the mpg, plug wire, ground wire, plugs, (oxygen, temperature, MAF sensors), fuel injectors.........
I got sludge problem, losing engine oil, so the smoke did not go away.
Lots of small things need to be took care for this 13yrs old car.
But I still like it very much!
Old 03-31-12, 03:26 AM
KS13
KS13's Avatar
Can someone direct me towards a MAF Cleanup DIY for 02 ES?
Old 10-18-12, 09:28 PM
MrShim78
MrShim78's Avatar
[quote=download;6458836]Ref to this helpful link:
Hi download..so did your mpg get better ? i am going to clean my maf soon probably next weekend
Old 10-19-12, 12:35 AM
download
download's Avatar
My mpg is not good too, because mostly city driving.
I found the big white smoke was the result of Sludge.
And engine sludge result from losing engine oil.
And collect and output when the morning start.
I can't open the engine to clean it out.
Will try the oil catch tank method to solve the losing engine oil.
Old 03-08-16, 06:24 PM
Jaggernaut
Jaggernaut's Avatar
On the back of the can on CRC MAD Sensor Cleaner, it states not to be use on most Lexus cars, especially if you car has a Karman-Vortex AFS. My question is does the 2000 es300 have that specific air flow sensor? I might end up answering my own question. Ill post if I find out so.
deanaustin
07-24-14 07:12 PM
ls400geek
13
02-12-13 03:08 PM
DesertDave
06-27-11 01:24 AM
happy_es3
04-03-09 08:30 AM
swat1727
09-29-08 03:35 PM
Quick Reply: DIY Clean 98 ES300 MAF sensor
