ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Old 12-16-14, 11:37 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
DIY: Lexus ES350 Footwell Lighting
Old 10-16-10, 08:34 PM
ekwlee
ekwlee's Avatar
Cool DIY: Lexus ES350 Footwell Lighting
Ok, part finally got in and I did it, I hated the non-led footwell lighting, esp because you couldn't see it at night, or barely even see it.
Hardness scale: 2; [1-10 (Easy-Hard)]
Part #: 81080-22040
Amt Needed: 2 of the above part numbers
Cost: Approximately $40
Directions:
1. Order the Parts from your local dealer!
2. Secondly you need to locate the lights underneath the steering column (L) and underneath the glovebox (R). See below
Left:
Right:
3. Let's work on the left side first; Just place your thumb on the light itself and push upwards hard. The light should pop out, and it should look like this...
4. Unplug the light and put one of your lights in....then it should look like this!
5. Reorient the light back to the original position, and push the light back into place (its going to be a hard push)
6. Go to the right side of your car (this part is just a tad bit harder)
7. Locate the light underneath the right side
8. Remove the rubber cover from the light (it is just covering the outside of the light). It just looks like below...
9. On the left corner, of the bottom most covering, pull strongly where the bottom panel and the glovebox panel meets.
10. The panel should come down at that corner, and continue to slide your hands along the edge towards the right of the car until the whole panel comes out.
Right Corner
11. The middle of the panel should look like this...
12. Remove the light and plug in the new light, replace the light in the same place.
13. Make sure when you put the panel back you put the panel ends back into the two holes you see in the back (insert pun in here)
14. Put the rubber cap back on
15. Pau! (All done)
After Pictures
Old 10-16-10, 09:04 PM
Blueshark
Blueshark's Avatar
Can you show us the final result and difference in brightness ? Also, thank you for the DIY, i'm doing it soon with leds strips.
Old 10-16-10, 10:11 PM
ekwlee
ekwlee's Avatar
done...now to get rid of those green lights..lol
Old 10-18-10, 06:50 PM
tC350
tC350's Avatar
FYI those orange light you took out were LEDs....
Old 10-19-10, 01:57 AM
ekwlee
ekwlee's Avatar
lol...well..if they are..they sure are ugly and low output
Old 10-19-10, 07:09 AM
SteadyEddy
SteadyEddy's Avatar
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
Well done!!! Great how to! Thanks
Old 10-19-10, 06:18 PM
acdapast
acdapast's Avatar
great DIY, i just did mine and looks great.
are u planning to do the green lights as well?
Old 10-20-10, 12:51 AM
ekwlee
ekwlee's Avatar
Pash..I wish..need to do more research first..I'd rather do the steering wheel control first (change it to the 2010) first
Old 02-11-11, 12:33 PM
JForce
JForce's Avatar
Hate to revive an old thread but will these lights work?
http://www.v-leds.com/Exterior-LED/C...viewsTabAnchor
My RX330 has the same setup but I was wondering if I can get these LED lights to fit in the stock ones.
Old 02-11-11, 03:39 PM
Jimbo68
Jimbo68's Avatar
Now let's get started on replacing those rubber sandals.
Old 02-14-11, 04:46 AM
ekwlee
ekwlee's Avatar
lol..come on..i live in hawaii..that's ALL we wear...
Old 02-14-11, 04:47 AM
ekwlee
ekwlee's Avatar
nope..not the footwell ones i think
Old 09-26-12, 07:48 PM
jcat_350
jcat_350's Avatar
hmm..part is from a venza eh? $12 per light for a little guy like that is a bit outrageous no?
Old 09-27-12, 02:08 PM
wpbmed
wpbmed's Avatar
Default better
Go to lexuspartsnow.com anad get the exact same part for $12 each, instead of paying $40.
Old 09-27-12, 02:12 PM
wpbmed
wpbmed's Avatar
What year is your ES?
Quick Reply: DIY: Lexus ES350 Footwell Lighting
