ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
ES=Camry brakes?
Old 09-19-12, 11:20 AM
Slvr surfr
Slvr surfr's Avatar
Default ES=Camry brakes?
Hey fellas! Both of my girlfriends have ES350's. Ones an 07 and the other one is an 08. I want to know if they use the same brake pads the same year Camry does or is there a difference. IronToad does have good prices on the ES pads but if they use the same as the Toyota ones then why not save a couple of dollars? Also, i have a 05 LS whos brakes pads are the easiest to change in my experience but i would like to know if the ES's are similar or much harder to change out or is there anything special i need to know other than the usual brake change method? Thanks in advance.
Old 09-20-12, 01:46 PM
Slvr surfr
Slvr surfr's Avatar
Old 09-21-12, 12:30 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Can't do it right now, but an easy way to find out is to go to someone like Napa's website, punch in info from both cars and see what brake pad number it skits out... if they are the same, then viola... now, might be a catch with these... Lexus will all be V6 models with 4 wheel discs, whereas, Candy's might have different brakes between 4 and 6 cylinder, and 4 wheel disc vs drums in the rear...
Old 09-21-12, 12:31 AM
mitsuguy
mitsuguy's Avatar
Man, autocorrect owned me on that, but you should get the idea....
Old 09-21-12, 06:18 AM
Joeb427
Joeb427's Avatar
Brakewarehouse.com has the '08 ES and '08 Camry all models Centric Posi Quiet Ceramic front pads with the same part numbers 105-12950.
The brake pads are the same there.I'd still try a couple of more sites to make sure but they're probably the same.
Old 09-21-12, 09:20 AM
Slvr surfr
Slvr surfr's Avatar
Thanks guys for your response. But does anybody know how easy they are to accomplish? Anything special I need or are they just like any other brake pad change?
Old 09-21-12, 06:03 PM
larryr
larryr's Avatar
Default pad change
Just the same as the older cars. simple job.
Old 09-22-12, 03:06 AM
jacobjohn
jacobjohn's Avatar
both your girlfriends? sounds complicated...
annnnnyways, change the pads are pretty simple...don't remember anything that was different
Old 09-22-12, 08:16 AM
wpbmed
wpbmed's Avatar
all the same parts, and extremely easy to change.
Old 09-22-12, 02:49 PM
Slvr surfr
Slvr surfr's Avatar
Yeah both of them. Go figure! . At least if some acuses me of being in a Lexus with some woman, i can just say: honey they must've saw me with you! lol
Thanks guys! I changed them today and it was a snap. Almost as easy as my LS. But i did notice she needs rotors now. Do they just slide off or is there a hub screw of some sort? I forgot to check.
MrKayP
Suspension and Brakes
22
04-21-22 12:48 PM
Batmobile
07-03-08 06:55 PM
tony Stark
10-06-04 07:39 PM
gebo
09-20-01 04:38 PM
Quick Reply: ES=Camry brakes?
