ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
My 2007 ES350's Mod Thread
Old 02-02-13, 01:04 PM
  #46
twistedman
twistedman's Avatar
Looking good Sick! Keep it coming..
Old 02-02-13, 04:18 PM
  #47
chbow
chbow's Avatar
Originally Posted by SICK350
No problems at all, it went super smooth I got a lot of info off of here which helped quite a bit. Thanks I love the wood wheel, my es300 had one and I missed it.
I'm trying to find a wood shifter now to match, I think there about $325 off of Sewell.
The best prices I've found for those have been on eBay, it's also good if you know which other models have the same shifter.
Old 02-03-13, 11:12 AM
  #48
SICK350
SICK350's Avatar
I've been keeping my eye out for a good one on ebay, it's a hit and miss.
Old 02-03-13, 11:19 AM
  #49
SICK350
SICK350's Avatar
Default Alpine Bluetooth Microphone in factory spot!
Today I installed the alpine microphone in the factory spot, Let me know what you think. I still haven't got the wiring for the head unit so I can't test it yet.
I started by removing this small plastic piece put in the models with no factory mic.
Old 02-03-13, 11:21 AM
  #50
SICK350
SICK350's Avatar
Next I cut the plastic off the alpine mic so it would fit when I pop it back into the roof.
Old 02-03-13, 11:24 AM
  #51
SICK350
SICK350's Avatar
I used a couple of small zip ties and some clear silicone. I didn't cut, drill, or brake anything. Everything can be put back to OEM. Gotta Love Silicone
Old 02-03-13, 11:26 AM
  #52
SICK350
SICK350's Avatar
A little more silicone to hold the wire in place, makes for easy install!
Old 02-15-13, 05:46 PM
  #53
SICK350
SICK350's Avatar
PAC TATO Toyota interface, allows you to use factory amps and speakers with a aftermarket head unit.
Old 02-15-13, 05:48 PM
  #54
SICK350
SICK350's Avatar
SWI JACK Steering wheel interface, allows you to use factory steering wheel controls with aftermarket head unit.
Old 02-15-13, 05:50 PM
  #55
SICK350
SICK350's Avatar
PAC TR7 parking brake bypass, allows you to watch video without using parking brake.
Old 02-15-13, 05:54 PM
  #56
SICK350
SICK350's Avatar
XM Radio interface, allows you to control your XM radio from a aftermarket head unit.
Old 02-15-13, 06:00 PM
  #57
SICK350
SICK350's Avatar
Got to make all this fit somewhere
Old 02-17-13, 10:59 AM
  #58
mlacomb
mlacomb's Avatar
You'll have to let us know how you cram all that stuff in! I haven't had mine out yet, but I'm guessing there's not a lot of space behind the head unit for all that. I don't have XM and plan on bypassing the Lexus amps when I do my install, so I will save a little space - but I still want the steering wheel interface (once I've gotten used to them, I can't go back!)
Old 02-18-13, 10:05 AM
  #59
SICK350
SICK350's Avatar
Originally Posted by jacobjohn
Did you get the camera as well? Not sure if the 900 has this feature, but the 910 has this amazing feature where it will actually make a flashing square and beep when there's a moving object behind you while you're reversing out. Pretty awesome. You can also standardize the alignment lines so that they are as accurate as possible. Neat stuff! Here's a vidoe of it at work! When I have enough dough, I'm definitely going to try to install this HU
http://www.youtube.com/watch?feature..._ratqxY#t=393s
I haven't got a camera yet but I plan on getting one before I put everything back together, I've been looking for a good thread on a aftermarket camera install with no luck. I found a camera on ebay that replaces one of the licence plate bulbs, I added a link. If anyone has done this install or knows a good thread please let me know.
http://www.ebay.ca/itm/2006-12-Lexus...vxp=mtr&_uhb=1
Old 02-18-13, 10:14 AM
  #60
SICK350
SICK350's Avatar
There's actually quite a bit of space back there, I also have a Bluetooth module and a head unit booster I have to squeeze back there. You should have more than enough room for a amp bypass and a steering wheel control interface.
Quick Reply: My 2007 ES350's Mod Thread
