General EV Conversation
#541
#542
I've been experimenting with tire pressures on the EQS over the last few weeks. My priorities are ride comfort, steering feel, handling, efficiency, probably in that order.
The factory recommended settings are:
I tried the max load setting at 47 Front 43 Rear and found the ride quality to be too stiff (for reference I'm already on run-flat tires which doesn't help anything).
I tried 43 Front 43 Rear. This wasn't too bad. I thought I liked it at first. It seemed to make the EQS feel a little lighter on its feet and I liked the steering feel but I was feeling the road a little more than I'd like from a car like this, especially on the highway.
I tried 40 Front 40 Rear. Ride quality was better but not as much as I thought it would be. The EQS was feeling a little heavier now, the steering felt a touch heavier and more numb.
I tried 38 Front 38 Rear. I found ride quality to be getting worse again. It wasn't feeling stiff but I was also feeling bumps I wasn't used to feeling. At these pressures, I'm now also concerned about long distance efficiency.
I went back to the stock 41 Front and 41 Rear and found that it really is the best of all worlds. This seemed to have the best ride quality, best steering feel, it retained the more effortless and light on its feet feeling, etc. It was just very comfortable and very well balanced. It shouldn't be too surprising as I'm sure there's a reason the engineers settled on these pressure values, but I found it really surprising how much of a difference a couple pounds of pressure makes.
- Normal Load: 41 Front 41 Rear
- Max Load: 47 Front 43 Rear
AMIRZA786 (12-10-23)
#543
signdetres (12-10-23)
#545
#546
I think “high” is relative. Depends on the vehicle weight, wheel/tire size etc.
Our EQS weighs around 6200 lbs and wants 41 PSI all around.
Our Model Y weighs around 4400 lbs and wants 42 PSI all around so if anything, I’d say our Model Y is running a bit high. 🤷🏻♂️
#548
You can also run them at 41 with no issues, which a lot of Tesla owners do
#549
#550
Apparently Elon tweeted that it could be run at 39 PSI for comfort with only a 2% range hit. But yeah I was looking on the Tesla forum and a shocking amount of people are running them at lower than recommended tire pressures. Even some running at higher than recommended for better efficiency.
#552
#553
You probably get better range or whatever with how they recommend it.
#554
#555
It's no longer in the fuel door now. There's a color chart there that explains what the different colors mean for the charging status light. There are now (somewhat confusingly) multiple stickers by the door. It took a sec to figure out what pressures I actually need to be running
The following 2 users liked this post by SW17LS:
AMIRZA786 (12-10-23),
