home charger
#181
#183
You should strike!
#184
SW17LS (10-19-23)
#185
But even if they do, PG&E did not have to spend more capital to get the electricity. Basically, I am my own company, funded by me. FYI, I love my solar.
#186
back to home chargers ... ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
i have approved deal and electrician to have the chargepoint flex wired charger installed in my garage. it will happen shortly after the electrician receives the charger. i told electrician i want a 60A circuit and he calculated it will take 35ft of wire to get to the charger location from the panel, which is a big chunk of the cost.
![Ohyeah](https://www.clublexus.com/forums/images/smilies/OhYeah.gif)
The following 3 users liked this post by bitkahuna:
#187
Excellent! What was the cost if you don’t mind sharing.
#188
Sounds about right, my neighbors was $1,500. The run of cable is a big expense, that’s already done at my place I just have to have it run into the garage and finished.
#190
Wire isn't that much 40 feet is $200-$250.
#191
If your panel has the empty slots and just needs the wire run 35 feet...
Dam, I would've done it myself.
Wham, bam, thank you mam, done easy peasy.
Of course I don't recommend it for newbies, not a good diy for first timers. Lol
#192
I don't know what the wiring codes are in Florida, but here you have to run it through pipes. That means the cost of the piping, bending and cutting an sometimes putting them through walls or roofs and securing them
#194
AMIRZA786 (10-19-23)
