home charger
That Mustart charger is going to work just fine, 25 amp is close enough to the 80% of capacity threshold. You should almost always be able to top up overnight.
Couple of other things to consider in addition, a 10-30 to 14-50 adapter comes in handy particularly with my second tip which is I think it's sensible to also consider a variable output charger at some point so you are covered for almost all bases. The ones I use most often will let you set the charge rate to 6/8/12/16/20/24/32/40 so you limit the risk of pulling too much current on an unfamiliar circuit that might not be up to the job.
i can always return the mustart and get a variable which i could then use in my main garage when that's hooked up. thoughts?
thanks!
i also saw ref to 10p-30r adapters... i assume p means plug and r means receptacle?
thank you. saw those 10-30 to 14-50 adapters... so if i got a variable charger with 14-50 could i use it in the barn 10-30 outlet with an adapter? i was worried it might not be safe.
thanks!
thanks!
To your other questions you'll get as many recommendations as there are EV owners here, but my own view is that you should cover as many bases as you can, so a charger that can charge at both 110 and 240 and also be able to vary the rate helps. I also like to have a charger in the vehicle at all times. So I'd consider something with more flexibility in addition to the Mustart and that way you can leave one in the vehicle and have one ready to go at home.
With that 25 amp you're going to be able to go from completely empty to full overnight, and because you're rarely empty and rarely charging to 100% you really probably don't need anything more powerful, but sometimes a little extra charging speed never hurts. I never have to use my 80amp charger, I've rarely have the need, I get by just fine and generally charge mine at 30 or less as I'm usually just topping up to 80% or so for regular driving.
thanks again. about carrying a charger in the car... i don't really get that unless you know what your options are likely to be wherever you're going, unless you just carry level 1 (120v), maybe 14-50 and 10-30 and maybe 6-50 adapters or am i way overthinking this?
can you recommend an adapter and what charger(s) you're using?
you said the adapters aren't cheap, and maybe one like this ($30) isn't the right kind?
https://a.co/d/6tSAI9h
i am leery when it basically says convert a 30A 10-30 outlet into a 50A 14-50 because of course you can't do that unless the wiring and breaker support more current. with rule of thumb a 50A circuit breaker supports 32A charging, and a 60A supports 48A from what i've read.
The point about the chargers is just to cover all bases. it's just like insurance. When you need it, you're glad you had it. You'll likely be fine with fast chargers, but if you're doing something like Steve was the other day you might be traveling somewhere with limited public charging but an available dryer outlet. That's where this stuff comes into its own.
The charger I keep in my truck is this one, it's not cheap but I got it for around $200 off current retail. It has both a 110v and a 14-50 plug, and I also carry a 10-30 to 14-50 adapter similar to the one you posted. The charger covers all bases, L1 and L2, and a lot of charge rate options.
This is my 80 amp charger - https://chargers.ford.com/ford-charge-station-pro
and yes, you're quite correct, the adapters just enable the connection. You don't magically turn 30 amps into 50..!
What's the max current your charger can draw? With Tesla's, the mobile connector only charges at 32A max. The hardwired wall connector can do 48A. I've also heard of issues with cheaper outlets, so if you go that route, don't skimp. It also requires an expensive ground fault breaker. I think most direct connect chargers already have that covered.
Our direct connect wall charger install required upgraded service (100A -> 200A). That includes a new panel and breakers, plus working with the city to change our connection cable outside to the house. Then running 55' of 6 gauge copper wire (2ea) and 1 10 gauge. All through 3/4" metal conduit, due to code in this area. My first estimate was almost $14k! I got a couple others and chose the company with the better reviews and experience and paid $4,500. That said, I was surprised by how many companies never even called me back. I called 10 and only heard back from 4. Bottom line, get as many estimates as you can.
AMIRZA786 (10-07-23)
One more thing, Bit, also consider a Tesla adapter. You can't use superchargers for now, not until next year and with a specific adapter, but there are lots of Tesla destination chargers you can use with the adapter and there are a lot of people who have Tesla chargers at their homes. The adapters let you use these chargers.
I have this one from Tesla Tap, made specifically for my Lightning.
http://www.umc-j1772.com/index.php?r...product_id=174
The following 3 users liked this post by swajames:
head spinning...
but thanks for all the info!
this $#!+'s expensive... adds up
newest adapter from tesla tap is $300![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
https://www.umc-j1772.com/index.php?...product_id=160
couple more impressions from today's driving...
car is quick! can't imagine calls like tesla plaid or r1s top trim (835hp)
car makes a low 'space age' type sound outside at low speed so pedestrians aren't killed
i wish i could turn it off.
as i walk toward the car with key fob in pocket the doors and trunk unlock automatically.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
level 1 charging is a complete joke.
got my first level 2 charger that's 'only' 25A because my barn's dryer outlet is 10-30 type with 30 amp breaker. when i get the house outlet put in the garage it will be 50 or 60A breaker.
in a quick test, the new charger seems to be about 10x faster than the level 1.
the car talks (outside) when you start/stop charging.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
the driver's seat has a power leg / thigh cushion for when taking naps while charging.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
the rear seats slide back/forward and also recline.
there's a "driver's only" climate mode to save wasting using power for cooling a passenger who isn't there.
quirk, to get to the cooled seats setting, you touch a lable called "warmer"
My advise (from a guy with 4 EV's
BayeauxLex (10-09-23)
) is to buy an actual charging station, minimum 40 amp, and install a 240v circuit with either 50 amp or 60 amp breaker. Yes, there will be a bit more of an upfront cost, but you will have a faster charging experience, dedicated charging cable with cable management, and it will all pay for itself pretty quickly. Also there is a 30 percent Federal tax credit up to $1000 for charging stations
