It was some time ago, but back when Lexus introduced the first IS300, the industry knew about it, and its details, well in advance, although it can also be argued that because it was so strongly based on the non-U.S.-market Toyota Altezza, many of those specs/details were already known. As you probably know, I liked the 1Gen IS300, and bought one...that's how I joined CL.
it was over 20 years ago, and the 'industry' knew details, as you point out, because the car was already on the market as the identical altezza.
When have you EVER known Lexus to release a bunch of information and details early? It's always been their MO, don't act surprised.
Most recent example is the LX600, which had its first spyshots in August last year, and the full reveal came two months later with almost every major spec sheet number. Meanwhile we first saw images of the RZ production model with some technical details in December last year, now 3 months on we have yet to see any official numbers.
As you say, folks only knew those details because the car had already been out for a couple of years in Japan as the Altezza. It wasn’t due to any early press release from Lexus.
Sorry Mike not the same scenario at all and 20+ years ago isn’t all that relevant.
lol so spyshots are now part of the official Lexus press release cycle?
website and magazine pics don’t change that they are notoriously and annoyingly tight lipped on official info until the last minute. Expecting anything else will just get you frustrated
That's my point. The LX's entire debut cycle from our first view of it in public to its full showing with every major spec sheet number was shorter than the time it's taking for the RZ to complete a fraction of that cycle. More to the point, the LX had most spec sheet numbers the moment it was officially announced, while the RZ still has nothing 3 months after it was announced.
I don't recall the last Lexus model that took this long in between showing the production version to announcing the technical details and specs.
Perhaps RZ is compact like Motorola says, because the vehicle below does look a little compact on big wheels with beautifully short overhangs [I can't stand long overhangs], but then it should be NZ, because RZ tends to denote midsize?
The other possibility is that RZ is a medium sized 4 door coupe, and the 4 door coupe nature makes it a little smaller than the RX?
I think more of the latter, but you never know...
Technically the BZ4X has a longer wheelbase than the RX (112 vs 110 inches), so despite being a smaller car on the outside it still has more passenger room on the inside. That's how I think they can justify giving this a midsize R name even if it's dimensionally identical to the BZ.
I don't have equivalent photos from the same angle, but to me, the RZ looks bigger than bZ?
RZ seems to have bigger wheels, taller, longer wheelbase and shorter overhangs?
But of course, all questionable...
They look almost the same size, even the door for the charging port cover looks proportionally the same and is in the exact same position. The Lexus has slightly longer overhangs and larger wheels that better fill in the wheel gap.
The old ICEV Toyota K Platform certainly has a shorter wheelbase than EV e-TNGA, but it could be anything...
The charge door location hints that most everything is stuffed under the hood meaning no funk space. Hopefully not but looks that way.
or toyota has figured out if people tow it would be a better idea to have the charge port at the front. A simple concept that other manufacturers are unable to figure out.
