Lexus develops 800V Fast-Charging EV Architecture
But only for EV's with 100 kWh batteries or larger:
Lexus Finalized 800-Volt Architecture, But Not All EVs Will Get It
Is there a place or website where Kilowatt hours, time to charge, how to figure out what a vehicle would cost to charge, etc., is in layman's terms? I see a lot of discussion of how many miles per kWh etc., time to charge dependent on battery size, capability and so on and so forth, but I find it a bit confusing. Maybe someone who is well versed in this can give examples and can open a new discussion with facts/figures/examples for those of us who are not up on the efficiency of EV's. I surely don't trust someone at a dealership to tell me that a Mach-E is more efficient than a Model Y, etc., the only thing I see on a Monroney sticker is how far a vehicle can go on a charge. Nothing as to what it may cost to charge, how long to charge, etc. The old 'standard' MPG is/was pretty easy to figure out- regular or premium fuel and what one can expect city/hwy/combined. I'm sure I'm not the only one trying to figure out the true efficiency of the new PHEV/EV's coming to market.
kilowatt hours is the term used for battery capacity while kilowatts is the term used for charging rate/speed.
Time to charge is pretty well described on each OEM's site, but again, dependent upon what % you're starting at vs ending at.
costs are highly dependent upon what you're going to use to charge. Are you charging at home? here you can see avg cents per kilowatt hour in your state: https://www.eia.gov/electricity/state/
If you're dependent on DC Fast Charging, that can get pricey, as those costs (if the car you get/have doesn't have some free charging allowance) are typically at least 40 cents per kWh.
If you don't have some monstrous commute or intend to use it as a heavy road trip vehicle, and you can charge with a 240V type outlet at home, I can say that you'll almost never think about charging needs ever again.
Is there a place or website where Kilowatt hours, time to charge, how to figure out what a vehicle would cost to charge, etc., is in layman's terms? I see a lot of discussion of how many miles per kWh etc., time to charge dependent on battery size, capability and so on and so forth, but I find it a bit confusing. Maybe someone who is well versed in this can give examples and can open a new discussion with facts/figures/examples for those of us who are not up on the efficiency of EV's..
Now..
kWh of 1 is 1000 watts: if a microwave is rated is rated at 1000 watts, and one uses the microwave for 1hr, you would have used 1 kWh
Ten 100 watt lightbulbs, burned for one hour is 1 kWh
a 1000 watt floodlight is 1 kWh.
Below, the Polstar is least efficient, the Hyundai, then the Tesla
If an electric car is rated at 25 kWh, then it burns 25,000 watts in one hour. Or 25 kWh
What screws it all up is the US imperial system that converts it to mpg. In America, the kWH are slightly inflated because of the mile division.
If you follow the proper metric system, everything is divisible by 1, 10, 100, 1000 etc….
As per Toyota, they are targeting 25kWh/100km for the compact class of,SUVs.
You can apply kWh when it comes to EV motors. A 160 kWh motor X by 1.34 is 214hp.
You can apply kWh to the battery, the higher the kWh battery, the longer the range will be
And MPGe isn't bad. It helps customers relate to something they've known, and all measures are relative. 1 gallon of gas has the equivalent electrical energy of 33.7 kWh.
I don't believe this is true.... cars are being rated for efficiency in kWh per 100 miles (in the U.S.) So it's not time bound. It's not saying it'll used up 25,000 watts in an hour.
Why is MPGe is dumb? it is because kWh is metric and MPG is imperial.
It is correct. if a car is rated at 35 kWh per 100 miles, it would take 35,000WATTS of energy to travel 100 miles. That is what you would need to pump into the battery to drive that far.... You can power 35 100 WATT lightbulbs for one hour, or you can drive a 100 miles.
moving to metric…One litre of gasoline is the equivalent to 8.9 kWh. So a EV burning/using/exerting 35 kWh per 100km is the equivalent of a gas car burning 3.93 litres of gasoline per 100km. A Toyota Mirai is rated at 3.1/3.5 litres per 100km
Do you agree that’s the imperial system makes no sense? kWh per 100 km works better than kWh per 100 mile
Just we need a debate on the metric system.
people need to learn kWh/100 mile. So if someone wants to charge their new EV…and they stop at a charging station, and the rate of electricity is 10 cents per kWh…magically they can figure out their cost to charge their car. MPGe just confuses people…because batteries, electricity, etc are all in kWh
