EV Chat General discussion about electrified Lexus, other EV vehicle manufacturers and BEV, PHEV related industry news.
Mach-E recall. Deliveries halted. Oops...
Old 06-14-22, 08:30 AM
JeffKeryk
JeffKeryk's Avatar
Default Mach-E recall. Deliveries halted. Oops...
From the Mach-E forum...
Apparently every unit built up to 5/22/22 will be subject to a recall around the high voltage battery "contacters" welding themselves either open or shut.
All deliveries are halted. They don't know if it will be a hardware fix or software fix. Maybe both?
"Wait 'till the big boys get in..."
Old 06-14-22, 10:43 AM
Received 2,933 Likes on 2,470 Posts
That's a critical flaw either the contacts open and you have zero power or they weld shut which means the HV battery has no more fused protection.
Old 06-14-22, 10:57 AM
AMIRZA786
AMIRZA786's Avatar
Received 2,150 Likes on 1,672 Posts
Well that's not good for the Mach-e. Good for the Ioniq 5 though
Old 06-14-22, 11:14 AM
I suppose this helps Hyundai in the sense they can probably raise prices doesn't help them produce more cars. Consumers get the shaft, again.
Old 06-14-22, 11:17 AM
AMIRZA786
AMIRZA786's Avatar
Yeah I know. Hopefully it's an easy fix. I just read on MSN that it will be an OTA software update, but I don't see how a software update will fix an overheating contact, unless it's a software bug causing the issue
Old 06-14-22, 11:23 AM
... but I don't see how a software update will fix an overheating contact, unless it's a software bug causing the issue
Software limit on power output would "fix" the problem.
Reading the recall again...
Should the contactors weld closed while driving, a powertrain malfunction warning light will be illuminated on the next drive cycle, along with a no start condition
Uh, Ford. Why would you code it this way, waiting for the next drive cycle? This means if the fuse welds closed and you happen to crash the HV battery will stay live no matter what. How do engineers let stuff like this get into production?
Old 06-14-22, 11:29 AM
Och
Och's Avatar
Ford is screwed. Bronco engines are bad, now this.
Old 06-14-22, 11:41 AM
AMIRZA786
AMIRZA786's Avatar
Quality control. Trying to get cars out to customers as quickly as possible they must of rushed the process a bit. At least it's a software fix
Old 06-14-22, 11:57 AM
Received 1,225 Likes on 910 Posts
2nd part is my thoughts on this exactly, why is there a situation it's allowed to be driven with this?
Old 06-14-22, 12:05 PM
Probably because they don't want the headline, "Ford says stop driving your Mach-E until a fix is available".
Old 06-14-22, 12:07 PM
Margate330
Margate330's Avatar
High volts/amp switchgear is bulky and sometimes heavy so I'm sure it's a engineering design nightmare to keep it light and compact.
We don't see this problem a lot on industrial machines because it is usually way overbuilt just for this reason.
The machines don't roll on wheels so no real constraints unless an machine builder oem goes cheap on the copper and switchgear.
Looks like they are making revisions on stuff.
Old 06-14-22, 12:55 PM
But you really really should not. If it did fuse it will need to be replaced in that particular car and if it hasn't done so yet wouldn't it be wise to not risk it?
It is close to running a house without breakers.....probably would be fine but...
Old 06-14-22, 01:00 PM
JeffKeryk
JeffKeryk's Avatar
I believe Ford already limits full power to 5 seconds, due to overheat issues.
Old 06-14-22, 01:13 PM
Uh.....what? Then what does it drop to?
Old 06-14-22, 01:22 PM
Good question. From what I've read the bus bars in the battery pack are puny they can't sustain what the batteries themselves can put out. I wonder who makes that main fuse its only job is to blow when needed not weld closed that's the worst failure possible for such a device.
Quick Reply: Mach-E recall. Deliveries halted. Oops...
