EV Chat General discussion about electrified Lexus, other EV vehicle manufacturers and BEV, PHEV related industry news.
Long distance trip ev (non Tesla) charging still a big problem
Old 12-28-22, 12:14 PM
  #61
Received 2,730 Likes on 1,956 Posts
Originally Posted by patgilm
The main issue for me is that when I travel like I did a couple days ago I don’t want to have to plan to stop. I just want to stop where and when I want. If I’m hungry and I need to charge up how do I know that there is a place I want to eat and charge in the same parking lot or general vicinity where I could walk to do both. If by chance I can’t/don’t want to do both at the same time, that equals two longish stops.
No question on a long unfamiliar trip like that, the trips I take though are more ordinary and I’ve taken them a ton of times, and I always stop at the same places. For instance I usually stop at the McDonalds in Woodstock and get something to eat, always stop at the WV welcome center to pee, when I had cars that didn’t have this range I always stopped in White Sulphur Springs for gas…adjusting to stopping in Lexington for 20 minutes wouldn’t be a big deal.
SW17LS is offline
Old 12-28-22, 12:17 PM
  #62
lamar411
lamar411's Avatar
The problem with this thread and many others who share the same view is that they are trying to force a circle block in a square hole. I don't think any of the people in this thread are proponents of taking EV's on long road trips, they acknowledge it is a shortcoming. But the anti EV crowd keeps forcing a non issue.... its like the people who **** on EV's and towing. No duh if you take a big Ford Lightning and take it somewhere cold and make it pull a trailer your range will suck? Is that not known from the past decade of EV's being on the road?
At the end of the day, buy the vehicle that suits YOUR NEEDS. I commute to work and bumble around the local areas in my free time but I almost never drive more then 100 miles a day. I also don't go on long road trips as I would rather fly. An EV would work for me perfectly. BUT i don't own one as I live in a condo and don't have a charger. So it doesn't work for my current situation. Which is fine...
If you were a consumer that needed a lot of space, towing capability, long distance range, you have a full market of ICE vehicles. EV's aren't stealing your gas engines from you. Buy that.
/thread
lamar411 is offline
Old 12-28-22, 12:22 PM
  #63
/thread
Exactly…and we are a FAR way off from having EVs as the only option.
SW17LS is offline
Old 12-28-22, 01:43 PM
  #64
Received 2,439 Likes on 1,599 Posts
Nobody has said an EV is a great option for long trips, so your point makes no sense.
YOU have been stating they're a reasonable option because charging doesn't take long, etc. i have even made this thread NOT about tesla, because tesla is an ok option to me on long trips.
YOU are making this about something it's not. i'd really appreciate you not crapping all over threads you don't approve of.
You may not be “anti EV” but literally everything you post about EVs is about their shortcomings.
i posted a video, about a long trip where the youtuber, a MASSIVE ev fan, despite LOVING the bmw ix, shows the shortcomings on a long road trip (doesn't have to be 1100 miles like he did).
there's plenty of positive ev threads you can fanboy in if you want. this was meant to be informative. if you don't like it, you're free to not post in it (please).
bitkahuna is offline
Old 12-28-22, 02:00 PM
  #65
spwolf
spwolf's Avatar
Originally Posted by AJT123
So if I had a fully charged Tesla the range wouldn't change at all if I had a 1.5 hour commute each way that was 17 miles? It would come home with approximately 35 miles less after B2B traffic for 3 hours say in the brutal heat A/C blasting? Genuinely curious. That was the commute situation when we were there, West LA to Torrance and back.
I couldn't even break 10MPG in my LS430 out there, it was bad. But I was in the thick of it, gridlock.
no, it would not spend 0% on cooling you but you would come home with 50-60 miles less (which is stupid way to calculate battery - you could come home with 10% less battery). And you would recharge at home at equivalent of 2x-5x less than paying for gas at gas pump which means you would not care at all if it spent some energy cooling. EVs are still using lot of energy when AC is running on full, when you drive fast or short commutes. But it does not matter as much since you are not paying a lot for it. IE if i drove super slow in the city and dont use heating/cooling, i would die inside, and pay 30% less in electricity cost. But i pay almost nothing right now, so how much is 30% of almost nothing? $5 per month? For $5 per month, i do 0-60 all day long, and pre-heat/cool my car anytime.
spwolf is offline
Old 12-28-22, 02:15 PM
  #66
swajames
swajames's Avatar
this is absolutely false. AC in a modern EV is extremely efficient. You would not lose 10% from your SoC with moderate AC use for an hour or so. It gets hotter in my part of California than it does in LA, and my own observed AC consumption is generally reasonably negligible. My vehicle reports what has been consumed on powertrain, climate, accessory use and so on after each trip, and the AC impact in slow commuter traffic is almost always well under 5%. It’s rarely above a couple of percent. Heating has a much bigger impact than AC.
swajames is offline
Old 12-28-22, 02:49 PM
  #67
When have I ever said that an EV for a long trip is a good option? I have never said that. It remains for me the only negative in my own decision whether or not to buy an EV. I wouldn't even consider Tesla an ok option on a long trip. I have said that occasional charging for 15-30 minutes is not that big a deal, but of course having to stop 6 times for 30 minutes each on a trip is a HUGE deal.
I would also suggest that you talk to a moderator about someone "crapping on a thread" vs just disagreeing with you. I think I have been very fair and reasonable and courteous towards my fellow members in this thread. You however have been very rude to me, calling me a troll etc. If you don't want to read what I post, just put me on your ignore list.
Which we all agree with...I'm not sure why pointing out that most people don't drive regularly on trips like that makes you so angry.
SW17LS is offline
Old 12-28-22, 02:56 PM
  #68
703
703's Avatar
Originally Posted by swajames
this is absolutely false. AC in a modern EV is extremely efficient. .
not just EVs. Toyota and Lexus hybrids have one of most efficient A/c as well. With the baby asleep in back seat, in often leave my Rx450h on and the engine hardly kicks in to recharge the battery.
703 is offline
Old 12-28-22, 03:00 PM
  #69
Thats the hybrid system for you, thats one of the big benefits of ICE cars with 48V systems, the AC still works when the engine cuts off at a stop. In my cars with ESS and no 48V system the AC dies when they are shut off. That efficiency you are seeing is because your hybrid doesn't have a traditional belt driven system, same as an EV.
SW17LS is offline
Old 12-28-22, 03:07 PM
  #70
703
703's Avatar
Yes, however the Toyota inverter/compressor is driven directly by the 244.8V battery, so I think that's a bit more efficient than the mild hybrid of the 48V system?
703 is offline
Old 12-28-22, 03:12 PM
  #71
I'm sure it is, but the net result is the same benefit.
SW17LS is offline
Old 12-28-22, 03:48 PM
  #72
Received 2,933 Likes on 2,470 Posts
Electric motors are dramatically more efficient vs. belt driven compressor.
LeX2K is offline
Old 12-28-22, 04:14 PM
  #73
Margate330
Margate330's Avatar
How long can the heat or AC stay running if, for example, you were stuck behind a traffic jam or wreck.
Would say an hour longer trip due to stuff like that affect range much?
Margate330 is offline
Old 12-28-22, 04:40 PM
  #74
They will run for about 2.5 DAYS
SW17LS is offline
Old 12-28-22, 06:42 PM
  #75
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,273 Likes on 1,380 Posts
let’s knock off the personal commentary folks or thread will be closed
also, I’d really love to see answers to the questions in this thread from EV owners who have personal experience with many of the questions posted here, less conjecture from folks who don’t own one
DaveGS4 is offline
Quick Reply: Long distance trip ev (non Tesla) charging still a big problem
