Reprogram/re-install instrument dashboard cluster
3rd Gear
I am trying to import a car from Canada to the USA and in order to conform to US standards my instrument cluster must show an actual word BRAKE instead of an icon for a brake. The model of the vehicle is UX250h 2021. I called both a Lexus dealer and Lexus customer support, but both of them say they can't help. Is the cluster re-programmable or do I need to replace the whole dashboard instrument cluster?
You will need to find a cluster from a US UX250h if you want it to say BRAKE then have the mileage programmed into it to match your vehicle.
We can help if needed.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
![](https://www.clublexus.com/forums/signaturepics/sigpic178522_1.gif)
262-456-4147
Yes. We wouldn't know of other companies that can do what we do.
It's something you can do yourself though. Don't pay a mechanic $200 to remove a few screws and swap the gauge cluster.
__________________
262-456-4147
262-456-4147
3rd Gear
Thanks! Is this the right part?
https://www.oemvehicleparts.com/oem-...ter-8380076c11
__________________
262-456-4147
262-456-4147
I am in the same situation for my RX350h and my wife’s NX350. I found a solution for the NX, I was able to buy a cluster faceplate.
Might be a solution for you too.
I need to take out the cluster, open it and replace the faceplate. Only difference between the faceplates is that BRAKE light.
I believe you can buy a US standard used cluster and just replace the faceplate. No need to reprogram anything. That’s what I will do for my RX.
This is the one that I bought:
Zoom in and you will see the BRAKE at the same location of the brake light.
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/1179x1209/img_3623_40049b233d5d29b6724f80c0e9aa13152706b366.jpeg)
