turbo install
The question is are you going to upgrade the torque converter/transmission so that it can handle the boost? You going to change the transmission to something else? That hasn't been mentioned at all....
Dances with goats
i dont want a HUGE *** turbo... i dont want to get big numbers lol i just want an extra something something under the hood but regardless i'd feel better if i did get a stronger tranny
PUNKY did you have to modify the tranny because I would think that the computer not seeing this extra boost cause it doesn't have a map sensor on it would freak out. Intern that would make the tranny slip, not shift into the correct gear,not correctly up shift/down shift. I would figure that you have to modify the torque converter,clutch packs,shift solenoids.
