5 speed swap HELP!!
iight as yall all kno im doing a 5 speed swap in my sc and i have most of the parts already jus need a new clutch basically![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
-92 sc300 W58
-1jz/2jz Bellhousing
-1jz flywheel
-Oem sc300 clutch and brake pedals
-W58 slave cylinder
-sc300 clutch master cylinder
-Oem manual shift boot
-Driftmotion clutch line
-Trd shift ****
but here is the issue, im trying to identify the driveshaft i have, i kno the rear piece is from a 1jz jza70, which i wont need anyway cuz ima jus use the rear piece of my sc300 driveshaft..but the front piece of the driveshaft looks like its from a mkiii supra aswell but a W58. oh and the bearing on the driveshaft looks like its from a mkiii(w58) also
will i be able to use the mkiii front driveshaft piece with my sc300 rear piece???
-92 sc300 W58
-1jz flywheel
-W58 slave cylinder
-Trd shift ****
-92 sc300 W58
-1jz flywheel
-W58 slave cylinder
-Trd shift ****
but here is the issue i trying to identify the driveshaft i have i kno the rear piece if from a 1jz jza70, which i wont need anyway cuz ima jus use the rear piece of my sc300 driveshaft..but the front piece of the driveshaft looks like its from a mkiii supra aswell but a W58. oh and the bearing on the driveshaft looks like its from a mkiii(w58)
will i be able to use the mkiii front driveshaft piece with my sc300 rear piece???![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
-92 sc300 W58
-1jz flywheel
-W58 slave cylinder
-Trd shift ****
If its a w58 front it will now work with the r154..you can however use your sc 300 spline on the w58 driveshaft since its the same lenght as the supra r154 driveshaft.You will need a air chisel to get the spline off the shaft.
