A/C Questions...Plz Help!! *Dash or Glove*
Hey guys, first off id like to say my A/C works just fine in my car, when i was doing my single turbo build a friend of mine that was helping me wrench on the twins got alil to close to the A/C line by the firewall & he bent the dang Copper wire that bolts on the A/C line, instead of him tellin me he tried to bend it back and Snap it when....
So basically its the copper wire that is connected to the Expansion valve, so i need to replace it, Also since ima replace it my Evaporator has a lil leak so i decided i will replace that aswell while replaced the expansion valve..
Anyway, guy i would jus like to kno if i needed to pull the dash to get to the expansion valve & evaporator or can it be done through the glove box n lower kick panel??
Plz any info is well needed!!!
Thanks, Nate
Thanks, Nate
