Did u try the resistor? That's probably what ur issue is if u have no power
there is no resistor there is a black relay changed that already but still the blower is not working i tested the blower outside works perfect. the relay was working in a gs just like mine
Ok so the relay was changed but there is not power from the actual power wire itself? And what do u mean u tested the motor outside?
yes i took the blower motor outside and wire a straight wire to it to make sure it worked
the blower motor works perfect but i am not getting power on the red wire that feeds the blower motor. on the passenger side.
it is a module that it has located under the fuse box compartment in the engine bay i replaced that and walla problem solved i went nuts looking for this piece. now all i need to do is programm the factory key.
