help...aftermarket steering wheel installation for is350
hey there guys, i was wondering if someone knows how to install an aftermarket steering wheel with the NRG quick release, but id like to keep the horn function and be able to change the display on the cluster . Hopefully someone knows a lexus technician that may want to do this as a side job. I'm located in Miami,fl thanks in advance.
I don't think you'll be able to do as the sterring wheel controls are handled via the clock spring. Once you use an aftermarket wheel you probably wont be able to reuse the clock spring or mount the buttons unless you make some other type of button panel.
