Need help testing my ECU
Hey guys, I need some help...
Replaced my oil pump, and now the car cranks but wont start.
It's getting fuel and spark, tested both cam sensors and crank angle sensor and they're all good (tested with a multimeter)... even removed spark plug to see if motor was trully in TDC and it is... all marks line up perfect on cams and crank w/ oil pump...
so I'm lost now and wanted to see if someone close by in the orlando area has a running Aristo 2jzgte who will let me test my stock ECU to see if it'll start your car.
If you feel like you can give me a hand please txt or call me at 469-444-0606 or post here.
Thanks in advance.
Thanks in advance.
BlackIRON
Performance & Maintenance
12-09-15 02:08 PM
