Headlight Restoration!
The headlights on my '08 2IS have been yellow since I bought it last year, and they've only gotten worse. So today I decided to get them restored. I got them done by Jevel from GlossHouse Headlight Restoration and he did a great Job. The pictures don't do any justice as these lights now look brand spanking new. Here's some before(top) and After(bottom) pix. Let me know what you guys think!
I wouldn't recommend sanding your headlights, headlights have a thin layer of clearcoat. What will happen is the clearcoat with age and yellow out or flake off. These 3M sanding kits are a temporary fix and like the post above mentioned will only last a few months.
If you have yellow headlights lightly wet sand with 2500 grit, and use special compounds with a slow buffer or by hand. If 2500 is not enough you may need to sand the clearcoat completely off and reclear the headlights.
