FS: Klipsch Promedia SWS 8" 100w powered sub
$200
this is one kick *** subwoofer.
practically new. bought this last year directly from klipsch but hardly ever used it.
http://www.klipsch.com/product/product.aspx?cid=518
Specifications
FREQUENCY RESPONSE:
32-120Hz +/- 5dB
SENSITIVITY:
Closed loop system
AMPLIFIER:
Linear A/B
AMPLIFIER POWER:
FTC Rated; 100w continuous, 50Hz, <= 5% THD+N
AUTO POWER ON:
yes
INPUTS:
6 channel pass-thru 1/8" mini plugs, 1 RCA
OUTPUTS:
PHASE:
0° or 180° selectable
TRANSDUCERS:
8" fiber composite subwoofer, rubber surround
CROSSOVER FREQUENCY:
60Hz/90Hz selectable
SUBWOOFER:
8" front firing driver
DIMENSIONS:
11" W 14" D 10" H
WEIGHT:
32.5lbs
ENCLOSURE MATERIAL:
MDF
FINISHES:
matte black
VOLTAGE:
120 volt
FEATURES:
One volume control controls multiple SWS subwoofers. Blue LED power indicator. Power switch: off-auto-on
BUILT FROM:
2003
Specifications
FREQUENCY RESPONSE:
32-120Hz +/- 5dB
SENSITIVITY:
Closed loop system
AMPLIFIER:
Linear A/B
AMPLIFIER POWER:
AUTO POWER ON:
yes
INPUTS:
OUTPUTS:
PHASE:
TRANSDUCERS:
SUBWOOFER:
DIMENSIONS:
11" W 14" D 10" H
WEIGHT:
32.5lbs
ENCLOSURE MATERIAL:
MDF
FINISHES:
matte black
VOLTAGE:
120 volt
FEATURES:
BUILT FROM:
2003
brendanlim
03-05-05 07:37 AM
