FL small office/Home office Telephone system w/ auto attendant, music hold - $500
Old 04-09-09, 04:12 PM
2.5tsoarer
2.5tsoarer's Avatar
Default small office/Home office Telephone system w/ auto attendant, music hold - $500
Used for 9 months
DataLabsUSA DL-416 4 Line 16 Extension PBX w/ Music On Hold and Auto Attendant Telephone System with 2 RCA 4-line system phones
Technical Details
* Up to 4 Lines and 16 Extensions!
* Auto Attendant built-in allows a recorded OGM (Outgoing Message) and allows the caller to dial an extension number!
* Ringing Intercom, Transfer Calls, Secretary and Brokers Calls, Hold callers w/ Music On Hold!
* Rugged All Metal Case, Easy RJ-11 Standard Jacks for all connections -- perfect for the SOHO "do it your selfer"!
* Compatible with all single or dual line standard "off the shelf" touch tone phones supplied by the user - no proprietary phones necessary! Program with same phone - No computer needed!
DataLabsUSA DL-416 PBX is a stand alone telephone system for home or small offices. From its rugged all metal case to its advanced features, the DL-416 PBX compares with other manufacturers systems costing up to $2000.00. The DL-416 allows connections to up to four standard or Vonage VOIP telephone (CO) lines. It has connections with RJ-11 jacks for up to 16 standard touch tone phones -- even cordless phones. There is no need for expensive proprietary phones with this system. There is a built-in limited 3 part Auto Attendant or use this system with our optional EVM series of Voice Mail / Full featured Auto Attendant Systems. All extensions may access any external office PA system or stereo system. The DL-416 can access 3 way calling features on the outside lines for 3 way calls and remote transfers to cell phones or other outside lines. Caller ID information is passed to all assigned ringing extensions. Optional Low Cost CID-416 transfer card is not user installable. It must be ordered before the PBX ships and we install the card FREE. Any standard t/t phone can put callers on hold w/ music (external music source is also available). Transfer calls to any extension. Intercom calls are made without using outside lines. The DL-416 has a limited warranty of 1 year parts - 90 days Labor and FREE CUSTOMER SUPPORT for 90 days. This is a self contained unit with no PC required and is programmed by any standard phone. The DL-416 is the low cost, high quality SOHO Telecom solution for your business! The DL-416 PBX helps your business sound and function like a Fortune 500 Company at that all important moment -- your caller's first contact. This unit comes with a manual and plugs into 110 VAC 60 Hz Power.
RCA phones:
1. RCA 25202RE3 2-Line Speakerphone With Call Waiting/Caller ID EXECUTIVE Series
Indicator light gives you visual notice of incoming calls
* "New call" indicator ensures you don't miss any! Keep track of when you're needed — visually! "New call" green light indicator below the LCD display lets you know when you've got an incoming call. Now you can quickly switch from your current call to that important incoming call you've been waiting for. "Voicemail" light indicator on base flashes when you've got messages waiting; flashing stops once messages are reviewed. Must subscribe to local phone company's voice messaging service for these features to activate.
* 2 incoming lines for busy homes. Ideal for the home office! System receives calls on 2 separate phone lines — so you can conduct work and household business at the same time. Distinctive ring for each line lets you "hear" which call's for you. "Line in use" indicator lets you see at a glance whether the line's free.
* Hands-free talking with full-service speakerphone. Need to do more than just talk on the phone? Use the speakerphone when you need your hands free for the computer, notepad or anything else. Phone is headset compatible for added freedom of movement.
* ID callers before answering — with Call Waiting/Caller ID† capability. Always be prepared! Call Waiting and Caller ID capabilities mean you know when you have incoming calls — AND who they are. The 99-name/number Caller ID memory lets you see who called while you were away.
* Backlit 4-line LCD is easy to read. The spacious Liquid Crystal Display (LCD) area records the name/number, time/day and number of new calls to be reviewed. Text can be displayed in 3 languages for your convenience: English, Spanish or French.
* 3-way conferencing makes meeting easy. It's easy to get everyone together! You can add up to 2 outside callers to your conversation with the handy conference feature.
* 16-number speed dial memory makes communication a breeze! Spend your time discussing, not dialing! Contact up to 16 frequently called numbers with 1 touch — by assigning each a speed dial button.
* 90 name/number directory saves time! No more hunting for phone numbers! Convenient memory index lets you keep up to 90 names and numbers in your phone's recorded memory for quick and easy recall.
* Connect communication devices to phone with data port. Use the data port located on the phone to hook up a fax, modem, answering machine — even a cordless phone! Line selector switch assigns 1 of the 2 phone lines to the externally connected device.
* Speaker, handset and ringer volume adjust for sound control. Monitor the acceptable level of noise for your work area — by independently adjusting the volume of the speakerphone, handset and ringer.
* Battery backup capability for uninterrupted service. Battery backup uses 3 AA-size alkaline batteries (not included) in case of power failure. Phone lines and AC power cord are also included.
* †Call Waiting/Caller ID service required from your local telephone company.
2. CA 25414RE3 4-Line Corded Phone
Designed for the SOHO (Small Office/Home Office) market, this telephone system is also fine for use in large homes. The phone base may be used by itself to receive (and use) up to 4 distinct telephone lines. You can also add up to 16 optional cordless telephone extensions (RCA H5400RE3) to extend phone service throughout your home or office. Other features include Caller-ID capability, 16 phone memories per extension, 4-Line LCD, Speakerphone at base, Intercom and Paging, and more. One line may also be assigned as a data port for use with a computer or fax system. 16 Programmable phone memory buttons (one touch/intercom) for easy access to frequently dialed numbers Redial / Flash-Hook / Hold/ Mute functions Do not disturb/privacy selectable Visual line status indicators 3-Way conferencing Expandable to 16 stations Headset jack (with control and indicator button) for adding an optional headset for handsfree conversations Receiver volume control Call transfer New voicemail message indication 8 Programmable ring tones Hearing aid compatible Compatible with GE-29487, GE-29488, GE/RCA-25403RE3, GE/RCA-25404RE3 / Not compatible with the older GE four line phones Not wall mountable
* Four-Line Convenience with Distinctive Ring and Line-in-Use Indicators for Each Line. Expandable to 16 Stations.
* Full Performance Speakerphone with Hands-Free Dialing and Auto-Transfer to Handset
* Call-Waiting Caller ID* with 99 Name-and-Number Memory
* Large, Easy-To-Read LCD Display
* One-Touch Redial
* 16-Number Instant-Access Memory and 94 Name-and-Number Memory Directory with Convenient Memory Index
* Data Port for Fax, Modem, or Answerer with Line Selection
* IrDA port enables synchronization with palm-enabled devices (separately available service)
3. RCA GE H5400 / H5400RE3 900MHz 4-Line Accessory Cordless Handset
* RCA GE 900MHz 4-Line dedicated accessory cordless handset for use with the 25413RE3, 25414RE3, and 25415RE3
* Caller ID
* 40# Caller ID memory
* Headset jack
* Redial/flash/mute/hold
* Page function
* Call transfer
* Digital volume control
* Intercom
* Backlit 3-line LCD
* Hearing aid compatible
* Ringer Control (On/Off)
* Black with silver trim
* Note: Maximum of one handset for each base system
2.5tsoarer is offline
EJC
ES - 6th Gen (2013-2018)
05-16-17 07:01 PM
Buzzer777
RX - 3rd Gen (2010-2015)
09-04-16 12:35 PM
Carver
09-03-11 07:09 PM
GFerg
11-20-08 06:38 PM
Quick Reply: FL small office/Home office Telephone system w/ auto attendant, music hold - $500
