1/2" Ingersoll Rand 2135Ti Impact gun
#32
I still have problems taking crank pulley bolts with this one.
#34
It may be a hit and miss. Some people can take it out and some people can't. But it goes to show that these guns are damn strong if they were able to take out some crank pulley bolts. But then again, how often do you need to take one out
I like using it to remove lugs. In fact it's too fast so I always have to dial down the pressure
#35
Here is the spec:
Drive (in.): 1/2
Average Air Consumption (CFM): 5
CFM at Load: 24
Speed - No Load (RPM): 9,500
Blows Per Minute (BPM): 1,250
Working Torque (ft.-lb.): 625 Forward/700 Reverse
Inlet Size (in.): 1/4
Min. Hose Size (in.): 3/8
Standard Bolt Capacity (in.): 9/16
Tool Length (in.): 7.34
Tool Weight (lbs.): 3.95
The ergonomics is awesome. It feels like a perfect match in your hand and the lightweight design makes it easy to use without fatigue. I like it more than the Snap On gun I use to have (very heavy front end).
Drive (in.): 1/2
CFM at Load: 24
GS300ToM
10-01-09 06:44 PM
