NJ FS Computer: Engineering Boards (mother boards)
$110 each, I have two. Buyer pays shipping, they are un-open from their box.
I know some about computers, but not too much. Those came from my mom's work place, her old company is a motherboard manufacturer in Taiwan.
These are currently on sale to customers for 400-500 each, but they are all pre-production just like the one I am selling now. They will go on the market soon probably under another designation.
My mom also put together some goodies, for you, such as power cords and cables for the board (the data cables for the HD etc).
Here are the specs, I will try to find some pics within a day or two If theres any question let me know, I currently run one of these boards for my desktop with Nvidia 8800 gts and 2 ghz of ram and its a beast of a game rig!
EL330-DREL330-DREL330-DREL330-DREL330-DR
Intelฎ
PROCESSOR
LGA 775 socket for:
-Intelฎ CoreTM2 Quad / Intelฎ CoreTM2 Duo
-Intelฎ Wolfdale 45nm processors
Q45 microATX Board
Supports Intel Enhanced Memory 64 Technology
(EMT64T)
Supports Enhanced Intel SpeedStep Technology (EIST)
1333/1066/800MHz FSB
CHIPSET
Intelฎ chipset
-Intelฎ Q45 Express chipset
-Intelฎ ICH10DO I/O Controller Hub
SYSTEM MEMORY
Four 240-pin DDR3 DIMM sockets
Supports DDR3 800/1066MHz
Supports maximum memory bandwidth of 17GB/s in
dual-channel mode when using DDR3 1066MHz
Supports dual channel (128-bit wide) memory interface
Supports up to 8GB system memory
Supports unbuffered x8 and x16 DIMMs
EXPANSION SLOTS
1 PCI Express x16 slot
1 PCI Express x4 slot
2 PCI slots
ONBOARD GRAPHICS FEATURES
Intel GMA4500
- Supports 3D, 2D and video capabilities, DX10 and
OpenGL 2.1
ONBOARD AUDIO FEATURES
Realtek ALC262 2-channel High Definition Audio
Two 24-bit stereo DACs and three 20-bit stereo ADCs
S/PDIF input/output interface
ONBOARD LAN FEATURES
Two Realtek RTL8111C PCI Express Gigabit controllers
Supports 10Mbps, 100Mbps and 1Gbps data transmission
IEEE 802.3 (10/100Mbps) and IEEE 802.3ab (1Gbps)
compliant
SERIAL ATA INTERFACE
Supports 4 SATA (Serial ATA) interfaces which are
compliant with SATA 1.0 specification
SATA speed up to 3Gb/s (SATA 2.0)
Supports RAID 0, 1, 0+1 and 5
IDE INTERFACE
Supports up to two IDE devices
Supports Ultra ATA 100/66/33
REAR PANEL I/O PORTS
1 mini-DIN-6 PS/2 mouse port
1 mini-DIN-6 PS/2 keyboard port
1 DB-25 parallel port
1 DB-9 serial port
1 DB-15 VGA port
2 RJ45 LAN ports
4 USB 2.0/1.1 ports
Mic-in, line-in and line-out
I/O CONNECTORS
2 connectors for 4 additional external USB 2.0/1.1 ports
1 connector for external serial port
1 DIO connector
1 front audio connector
1 CD-in internal audio connector
1 S/PDIF connector
4 Serial ATA connectors
1 40-pin IDE connector
1 FDD connector
1 24-pin ATX power connector
1 4-pin 12V power connector
1 chassis open connector
1 front panel connector
2 fan connectors
BIOS
Award BIOS
8Mbit SPI flash memory
ENERGY EFFICIENT DESIGN
Supports ACPI specification and OS Directed Power
Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
-Wake-On-PS/2 Keyboard/Mouse
-Wake-On-USB Keyboard/Mouse
-Wake-On-LAN
-Wake-On-Ring
-RTC timer to power-on the system
System power management supported
Microsoftฎ/Intelฎ APM 1.2 compliant
Soft Power supported - ACPI v1.0a specification
AC power failure recovery
DAMAGE FREE INTELLIGENCE
Monitors CPU/system temperature and overheat alarm
Monitors CPU/DIMM/3.3V/5V/12V/V5sb/VBAT voltages
and failure alarm
Monitors CPU/system fan speed and failure alarm
Read back capability that displays temperature,
voltage and fan speed
Watchdog timer function
TEMPERATURE
0oC to 60oC
HUMIDITY
10% to 90%
PCB
4 layers, microATX form factor
24.4cm (9.6") x 24.4cm (9.6")
Mic-in
Line-in
Line-out
PS/2 K/B COM 1 VGA USB 2-3 USB 0-1
PS/2
Mouse LAN 2Parallel LAN 1
Intelฎ
PROCESSOR
LGA 775 socket for:
Q45 microATX Board
(EMT64T)
CHIPSET
Intelฎ chipset
SYSTEM MEMORY
EXPANSION SLOTS
2 PCI slots
Intel GMA4500
OpenGL 2.1
compliant
IDE INTERFACE
1 DB-9 serial port
1 DB-15 VGA port
2 RJ45 LAN ports
4 USB 2.0/1.1 ports
I/O CONNECTORS
1 DIO connector
1 S/PDIF connector
1 FDD connector
2 fan connectors
BIOS
Award BIOS
Management
-Wake-On-LAN
-Wake-On-Ring
and failure alarm
TEMPERATURE
0oC to 60oC
HUMIDITY
10% to 90%
PCB
Mic-in
Line-in
Line-out
PS/2
