MD LS430 Projectors
These projectors are in mint condition but have no shrouds or motors. For those that want to do an HID retrofit -- these will work great!
$215 shipped!
$215 shipped!
what do you have to trade?
this is from hidplanet:
Lexus LS430 Super Wide Low Beam (Stanley):
Measurements for this projector are provided as "naked" - shroud removed, OEM mounting bracket removed, supplemental reflector was included in measurements. Also, assumed some "fat" (eg.: AFS spindles) would be trimmed. Where it says "trimmed", this is only an assumptive place where it was deemed best to trim without too much sacrifice. Some people will choose to trim more or not to use the whole or most of the shroud that gives this projector most of it's bulk. Please remeber that this is a very large projector/shroud combination.
Diameter = not measured as this projector comes with it's own shroud
Height = 117.05mm
Max Width = 134.32mm
Trimmed Width = 125.80mm
Width Bottom Reflector = 124.10mm
Length = 154.75mm
Length(tip of the lens to possible mounting holes) = 55.95mm
Length(possible mounting holes to end of bulb) = 98.80mm
Lexus LS430 shroud measurements:
Max Height = 143.62mm
Trimmed Height = 131.70mm
Max Width = 173.15mm
Trimmed Width = 154.30mm
Height = 117.05mm
Length = 154.75mm
sorry for the lag on the pics, here they are. they have the important part of the shroud on -- the bottom which spreads the light further. price drop to $215 shipped! Full resolution images to your inbox on PM request.
![](http://i35.tinypic.com/333k7c7.jpg)
![](http://i34.tinypic.com/2lxw420.jpg)
![](http://i34.tinypic.com/fz2rg4.jpg)
![](http://i36.tinypic.com/332c9e1.jpg)
![](http://img274.echo.cx/img274/4255/pix103ej.jpg)
NemeGuero
General Classifieds
05-30-10 08:08 PM
430, bracket, clublexus, dimensions, lexus, ls, ls430, luxurymods, m45, measurement, measurements, projector, projectors, retrofit, shroud, shrouds
