CA Snap on Parts Washer Solvent Electric Drum Mounted Auto Filtration
Brand New Snap-On / Snap On / SnapOn Parts Washer, Solvent, Electric, Drum Mounted, Auto Filtration, 16 gallon
$800 obo
NEW price, $500
MODEL PBD2622
Description:
Automatic filtration provides clean solvent through two separate filters. Pump circulates solvent through primary cartridge filter which separates solids down to five microns. Second stage clay filter absorbs remaining oil and grease in solvent. Solvent is continuously filtered for maximum cleaning effectiveness. Viton® seals in pump for maximum life. Complete with work lamp and flexible spout.
Additional Description:
Units feature unique "self-service" two-part filtration system. Mud bucket is located inside the drum, directly beneath the drain. It separates solids and particulates (down to five microns) from the pump. The pump then recirculates the particulate-free solvent up to the Sink Side filter element for final cleaning and absorption of oil and grease. Solvent is also routed through this filter when not washing parts. On-going filtration provides continuously clean solvent. Helps minimize waste and reduces required EPA paperwork. Disposable filters are easily replaceable.
Product Specifications
Stock # PBD2622
Name Parts Washer, Solvent, Electric, Drum Mounted, Auto Filtration, 16 gallon
Price** $1,358.55 (retail)
Brand Snap-on
Country Of Origin USA
Filtration Dual
Base Drum
Inside Dimensions, inches 7H x 26W x 17D
Fluid Requirements (gal) 8-10
Input, VAC (Hz) 120VAC (60Hz)
Pump Volume (gal/h) 180
Output Pressure, psi 50
Overall Dimensions, inches 34H x 30W x 21D
Open Height, inches 53
Replacement Clay Filter PBD26222
Replacement Cartridge Filter PBD26221
European Models (230VAC, 50Hz) PBDH2622EUR
$800 obo
NEW price, $500
MODEL PBD2622
Description:
Stock # PBD2622
Brand Snap-on
Filtration Dual
Base Drum
DaveN
04-28-08 04:01 PM
