WA Optoma 3D ready DLP Projector
Unit only has a couple hours on it...pretty much new!
Its a 720 3D ready DLP projector that I really dont have any use for.
$500
Really nice Projector![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Optoma Pro350W - Multimedia Projector 3DTV Ready
Small, sleek and stylish, the Optoma PRO350W provides a combination of performance and affordability. Features such as widescreen display, 2800 ANSI lumens, contrast ratio of 3000:1, lamp life of up to 4000 hours, filter-free design and low standby power consumption ensure that the Optoma PRO350W will not only save money in the long run, but also present a perfect, colorful, crisp image whether projecting a presentation or movie.
Specifications
General Information
Manufacturer-- Optoma Technology
Manufacturer Part Number- PRO350W
Brand Name- Optoma
Product Model- PRO350W
Product Name- PRO350W DLP Projector
Product Type- DLP Projector
Technical Information
Projection Method- Front
Projection Method- Rear
Projection Method -Ceiling
Lens
Minimum Lens Aperture- F/2.41
Maximum Lens Aperture- F/2.55
Zoom Type -Manual Zoom
Manual Zoom Factor- 1.1x
Lamp
Lamp Type- P-VIP
Lamp Power- 185 W
Normal Mode Lamp Life- 3000 Hour
Economy Mode Lamp Life- 4000 Hour
Standard Mode Brightness -2800 lm
Color Support -1.07 Billion Colors (30-bit)
Native Resolution -1280 x 800
Graphic Mode- WXGA
Maximum Resolution- 1600 x 1200
Minimum Projection Distance- 39.36"
Maximum Projection Distance- 32.80 ft
Diagonal Image Size- 300"
Native Aspect Ratio- 16:10
Compatible Aspect Ratio- 4:3
Compatible Aspect Ratio- 16:9
Contrast Ratio- 3000:1
Uniformity- 85%
Vertical Keystone Correction -40°/+40°
Maximum Vertical Sync- 120 Hz
Maximum Horizontal Sync- 91.10 kHz
Video
Video Signal -Format NTSC
Video Signal -Format PAL
Video Signal- Format SECAM
Video Signal- Standard HDTV
Scan Format- 1080p
Audio
Number of Speakers- 1
Speaker Output Power- 2 W
Speaker Output Mode- Mono
Interfaces/Ports
Interfaces -1 x HDMI Digital Audio/Video In
Interfaces- 1 x 15-pin HD-15 VGA In
Interfaces- 1 x 15-pin HD-15 VGA Out
Interfaces- 1 x 4-pin mini-DIN S-Video In
Interfaces- 1 x RCA Composite Video In
Interfaces- 1 x Mini-phone Audio Line In
Interfaces- 1 x Mini-phone Audio Line Out
Interfaces- 1 x RS-232 Serial
Power Description
Input Voltage -110 V AC
Input Voltage- 220 V AC
Dimensions 3.98" Height x 11.28" Width x 7.60" Depth
Weight (Approximate) 5 lb
$500
Specifications
General Information
Brand Name- Optoma
Lens
Lamp
Lamp Type- P-VIP
Lamp Power- 185 W
Graphic Mode- WXGA
Uniformity- 85%
Video
Scan Format- 1080p
Audio
Interfaces/Ports
Power Description
