WA Air Management kit & tank with Dakota Digital pressure Gauge
Everything is pre-assembled!
5 gallon Tank with 3/8th Valves.
Dakota Digital pressure gauge with 5 sensors
Tank also has a release valve with tube extension on the bottom AND a valve in case u need to fill up a tire or run power tools
Has the Gauge sensors already plumbed in, including the tank gauge.
Valves are plumbed,installed on the tank and wired up as well.
All the "work" is done, you only need a compressor and air bags! even comes with the relay pre-wired for the compressors.
the switch box wire (already installed) is color coded to easily add any type of switch box
Also comes with enough airlines for a full sized car.
Doesn't get any easier than this....$SOLD
![](http://i250.photobucket.com/albums/gg274/DriftGirl2/prd_lp_421.jpg)
![](http://i250.photobucket.com/albums/gg274/DriftGirl2/tvs.jpg)
FrictionSc
11-27-16 12:07 AM
nahhmeen
22
12-09-09 09:34 PM
