zenith hdv420 hdtv high def receiver
THIS IS A BRAND. I OPENED THE BOX TO CHECK IF EVERYTHING WAS INSIDE. ZENITH HDV420 WILL RECEIVE HI DEF PROGRAMMING BY JUST ADDING A ANTENNA . THE M.S.R.P. $399.95 HDV420 - Zenith High Definition Television Receiver Video Specifications Aspect Ratio: 4:3 & 16:9 Component Output/RGB Out: 1080i, 720p, 480p Composite Output: 480i (Only Available When 480i Mode Selected) S-Video: 480i (Only Available When 480i Mode Selected) Audio Specifications Dolby Digital: Yes Tuning System Specifications ATSC/HDTV: 1 ATSC Tuner Receives 18 Formats and Can Up-Convert/Down-Convert to 1080i, 720p, 480i/p, VSB Jack Pack Specifications A/V Out: 1 Set Antenna-RF: 1 RF-Input Calibration Port: 1 Serial Port Dolby Digital: 1-Coaxial, 1-Optical Hi-Res Component Video Out Y, PB, PR: 1-Set Switchable 1080i, 720p, 480p RF-Out: RF-Loop Out RGB Out: 1 (15-Pin Connector) S-Video Out: 1 S-Video Out Y, PB,PR/RGB Switch: 1 Remote Control Specifications Transmitter: Universal Remote with Navigation Keys Cabinet Description Specifications Finish(s): Brushed Metallic Special Features Specifications Antenna Tuning Indicator: Visual Auto Demo: Yes Auto Programming: Yes Channel Labels: Yes Closed Caption: Yes (Digital) Flashback: Yes Multi-Zoom Mode: Yes NTSC Outputs for Analog Hook Up: Yes Parental Control w/ V-Chip: Yes Sources: ATSC, Terrestrial/Cable (VSB) Surf's Up Favorite Channel Selection: Yes TAG Menus: Bit Mapped w/EZ Hook-Up Menu Required Approvals Specifications UL, FCC: Yes Additional Info Specifications Cabinet Dimension (H x W x D): 2.7" x 16.9" x 12.8" Cabinet Weight: 9 lbs. Dimensions with Packaging (H x W x D): 6.5" x 20.9" x 16.7" Power Consumption: 18 Watt UPC Code: 04464200972 4 Weight with Packaging: 15.7 lbs. Accessories (Included) Specifications AA Batteries: 2 Audio (L/R) Cable: 1 Component Video (Y,PB,PR) Cable: 1 Remote Control with Batteries: 1 User Manual.
asking 300 shipped
asking 300 shipped
GS300Rich
12-27-08 06:48 AM
Pearlpower
General Classifieds
07-19-08 03:09 PM
Free Agent
12-13-07 06:32 PM
