CO FS: Overland Drawer System, $550 Denver, CO.
Selling a custom drawer system for overlanding/camping. I built this from 3/4" and 1/2" plywood. Using dado and rabbet cuts for strength and durability. both drawers have a dado cut for the bottom to keep it strong and hold lots of weight. drawer ends have rabbet cuts too for durability. glued and screwed and brad nailed all of it together. It has 2 drawers with full 32" ball bearing rails for the slides with 260lbs weight rating on the slides. Each drawer uses a slide lock to keep it in place and are solid. I flushed the drawer fronts to allow it to sit flush in vehicle. no handles too for this reason. rounded off all the corners to prevent snags. I painted it in black spray on truck bed liner to blend in to vehicle and add some texture to prevent things from slipping on top.
also included are some dividers. I did not do a great job cutting these hence the cheaper price. It was my first try cutting these with the router so a couple are not straight. 1/4" wood still sits in them to create dividers. I will also include one false top to give more surface area and a table of sorts. I did not build to fill up wheel well to wheel well so that I could fit a fridge next to it. The fridge in the picture is 13.5" wide.
reason for selling is I want to build a new larger one. to integrate other camping items
measurements:
drawers inside 13 high X 13 wide X 32" deep (actual drawer sides 10.5")
overall 25.75"wide X 33.75 deep X 14.5" high
Other shops ask $1000+ for smaller ones of these. I am asking only $550. Local pickups only in Denver area
![](https://images.craigslist.org/01212_1NL7h6OsaMFz_0sB0sB_1200x900.jpg)
![](https://images.craigslist.org/00S0S_gNhidKVQVMlz_0t20CI_1200x900.jpg)
![](https://images.craigslist.org/01212_gbW47Tv2crTz_0t20CI_1200x900.jpg)
![](https://images.craigslist.org/00V0V_66IW1fD13n7z_0t20CI_1200x900.jpg)
measurements:
raine
Wheels and Tires Classifieds
33
06-08-09 07:56 PM
