Great Deals Share "great deals" that you have found online or in local stores.
CarMD handheld tester $20 off
Old 10-05-07, 10:41 PM
rcyo1
rcyo1's Avatar
Default CarMD handheld tester $20 off
$20.00 Off....CarMD handheld tester.
http://www.carmd.com/
COUPON CODE: APR14
EXPIRES: 12/31/07
Old 10-06-07, 12:40 PM
mikevanle
mikevanle's Avatar
It doesn't have an extension cord? That sucks. So you have to stick it into your port (prob underneath the steering wheel) and then bend down awkwardly to look at the code
Old 10-08-07, 06:34 PM
rcyo1
rcyo1's Avatar
Actually, It doesnt need an extension cord..... you power it on... connect it to the DLC Connector (Data Link Connector) wait for the four beeps.... then it retrieves the codes... then you pull it out and it will display any codes that are present. You can also link your tester to your PC with the USB cable and log on to the CarMD website to view the probable cause, fix, and cost to return your vehicle to health.
Old 10-09-07, 07:38 AM
benzo555
benzo555's Avatar
rcyo1 do you have one of these? worth the money?
Old 10-09-07, 07:37 PM
rcyo1
rcyo1's Avatar
yes.... i do have this unit and it's great. It's easy to use because you can retrieve codes and upload it to your PC .
5gears-IS
Great Deals
11-19-12 10:46 PM
5gears-IS
Great Deals
08-23-12 11:33 AM
lightwave76
Great Deals
12-29-06 10:41 AM
Quick Reply: CarMD handheld tester $20 off
