Champion Power Equipment Portable Generator $91.14!!
Closeout sale !
4450 peak watts....
This portable generator produces 3500 running watts of electrical power. This full featured generator is recommended for residential and recreational use. It is not recommended for commercial applications. It provides both 120 and 240Volt AC power and 12 Volt DC power. The modern overhead valve air-cooled engine combined with a large capacity fuel tank and automatic low oil shut-off provide dependable, care-free electrical power. Circuit breaker protection is rated at 15 amps for the 120 /240 volt twistlock receptacle and 15 amps and 20 amps total for each of the two 120 volt Duplex receptacles. Customers should be familiar with their electrical amperage requirements for selecting an appropriate generator, including the starting amps required for most motor driven equipment, which can range up to 3 times the normal running amps.
Parts America (check your zip to see if available in your area!)
http://www.partsamerica.com/productd...tNumber=C46535
Enjoy!!
4450 peak watts....
Enjoy!!
