ClubOnkyo Onkyo 5.1 receiver w/speakers and upscaling DVD for $119.99
A great deal for an ok system. Refurb factory.
Not top of the line but for the price....can't be beat.
LINK
Your getting a decent 5.1 Onkyo receiver, upscaling DVD, and speakers for $119.99 with new registration at clubonkyo. Or $129.99 without new registration.
Reviews at Amazon are pretty good. Price for a new unit at Amazon is $275.00 w/o the DVD unit. Does not appear to support HDMI but does support Component.
$40.00 more for 2 year extended warranty.
DVD not pictured below
![](http://www.shoponkyo.com/prod_images/Systems/HT-SR600S_front.jpg)
Receiver Section
Amplifier Section
Power Output
Front L/R
105 W + 105 W (6 ohms, 1 kHz, FTC)
Center
Surround L/R
Dynamic Power
180 W (3 ohms)
140 W (4 ohms)
95 W (8 ohms)
THD (Total Harmonic Distortion)
0.9 % (Rated power)
Damping Factor
60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance
200 mV/47 k-ohms (Line)
Output Level and Impedance
200 mV/470 ohms (Rec out)
Frequency Response
10 Hz–50 kHz/ +1 dB, -3 dB (Direct mode)
Tone Control
±10 dB, 80 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio
100 dB (Line, IHF-A)
Speaker Impedance
6 ohms–16 ohms
Video Section
Input Sensitivity/Output Level and Impedance
Video
1.0 Vp-p/75 ohms (Component)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
1.0 Vp-p/75 ohms (Composite)
Component Video Frequency Response
5 Hz–50 MHz
Tuner Section
Tuning Frequency Range
FM
87.5 MHz–107.9 MHz
AM
530 kHz–1,710 kHz
FM/AM Preset Memory
30 stations
General
Power Supply
AC 120 V, 60 Hz
Power Consumption
3.4 A
Standby Power Consumption
0.1 W
Dimensions (W x H x D)
17 1/8" x 5 7/8" x 14 1/2" (435 x 150 x 369 mm)
Weight
19.4 lbs. (9.6 kg)
Speaker Section
Speaker Type
Front/Center
2-way, bass reflex
Full-range, bass reflex
Subwoofer
Bass reflex
Drivers
Front
3 1/4" (8 cm) cone woofer,
3/4" (2 cm) ceramic tweeter
Center
Surround
3 1/4" (8 cm) cone
Subwoofer
8" (20 cm) cone
Frequency Response
Front/Center
100 Hz–22 kHz
Surround
110 Hz–22 kHz
Subwoofer
30 Hz–150 Hz
Output Sound Pressure Level
Front
85 dB/W/m
Center
85 dB/W/m
Surround
83 dB/W/m
Subwoofer
84 dB/W/m
Max. Input Power
Front/Center/Surround
120 W
Subwoofer
130 W
Nominal Impedance
6 ohms
Subwoofer
6 ohms
General
Front
4" x 10 3/4" x 4 1/2" (101 x 273 x 115 mm)
Center
10 3/4" x 4" x 4" (273 x 101 x 102 mm)
Surround
4" x 6 7/8" x 4 3/8" (101 x 175 x 111 mm)
Subwoofer
9 1/16" x 16 3/4" x 14 5/8" (230 x 425 x 372 mm)
Weight
Front
2.1 lbs. (1.0 kg)
Center
2.1 lbs. (1.0 kg)
Surround
1.5 lbs. (0.7 kg)
Subwoofer
14.8 lbs. (6.7 kg)
LINK
Receiver Section
Amplifier Section
Power Output
Front L/R
Center
Surround L/R
Dynamic Power
180 W (3 ohms)
140 W (4 ohms)
95 W (8 ohms)
0.9 % (Rated power)
Damping Factor
Frequency Response
Tone Control
Speaker Impedance
6 ohms–16 ohms
Video Section
Video
5 Hz–50 MHz
Tuner Section
FM
87.5 MHz–107.9 MHz
AM
530 kHz–1,710 kHz
FM/AM Preset Memory
30 stations
General
Power Supply
AC 120 V, 60 Hz
Power Consumption
3.4 A
0.1 W
Weight
19.4 lbs. (9.6 kg)
Speaker Section
Speaker Type
Front/Center
2-way, bass reflex
Subwoofer
Bass reflex
Drivers
Front
Center
Surround
3 1/4" (8 cm) cone
Subwoofer
8" (20 cm) cone
Frequency Response
Front/Center
100 Hz–22 kHz
Surround
110 Hz–22 kHz
Subwoofer
30 Hz–150 Hz
Front
85 dB/W/m
Center
85 dB/W/m
Surround
83 dB/W/m
Subwoofer
84 dB/W/m
Max. Input Power
120 W
Subwoofer
130 W
Nominal Impedance
6 ohms
Subwoofer
6 ohms
General
Front
Center
Surround
Subwoofer
Weight
Front
2.1 lbs. (1.0 kg)
Center
2.1 lbs. (1.0 kg)
Surround
1.5 lbs. (0.7 kg)
Subwoofer
14.8 lbs. (6.7 kg)
Silver is expired. Back to $299, the black version is available for $169 or $159 for new registrations. Still a good price.
LINK TO BLACK
LINK TO BLACK
Received mine today, had to costs them $30-$40 to ship both packages. Even comes w/ a 1 yr warranty. Still unknown what I'm going to do with it, perhaps give it to the boy when he gets his own place later this year. Killer deal.
lexilexus9
GX - 1st Gen (2003-2009)
09-06-11 01:47 PM
weird60625
04-16-11 12:34 PM
