~ Purolator PureOne Oil Filters 2 pack $4.38 ~
Nice, I just ordered 6 to qualitfy for free shipping
I usually just run down the street and pick up a SuperTech filter from walmart. Supertech filters are made by champion labs, same manufacturer as Mobil1.
Also, I buy the PL20195 filter. It's the same thread and base diameter as the GS300 filter housing. Only difference is that the filter itself is about 1.5" taller to provide more filtration area for less restriction.
The larger filter is confirmed to work on a 2JZ-GE and 2JZ-GTE for our cars. It SHOULD fit on the GS400/430 because it shares the same thread and diameter filter, but I can't 100% gaurantee it. The main thing you have to watch for is if you have additional room for a filter that is 1.5" taller. The GS300 has plenty of room and can use a 10" tall filter if they made one that big.
OEM filter specs:
Thread: 3/4-16 in.
Casing Diameter: 3.0"
Filter Height: 3.8"
The filter I use has the following specs:
Thread: 3/4-16 in.
Filter Height: 5.2"
As you can see the filter screws on and seals just fine to the factory oil filter flange. The only difference is that the filter is taller so you get more filtration surface area and thus lower resistance and better flow through the filter
OEM filter specs:
Thread: 3/4-16 in.
Filter Height: 3.8"
Thread: 3/4-16 in.
Filter Height: 5.2"
