Brand New 2009 Nissan Versa 1.6 4 door $7,800!!
MSRP: $10,865
Internet Special Price: $7,800
Link
No AC, PW, PDL
Manual (5 Speed)
CHANTILLY VA 20151
Warranty
Basic
36,000 miles / 36 months
Powertrain
60,000 miles / 60 months
14" x 5.0" steel wheels w/full wheel covers
Black bumpers
Black deck lid finisher
Black door handles
Black grille
Black manual folding mirrors
Compact spare tire
Multi-reflector halogen headlamps
P185/65R14 all-season tires
Variable intermittent windshield wipers
Interior
(2) front map lights
12V pwr outlet
4-way manual adjustable passenger seat
4-way manual driver seat
Audio pre-wire w/(4) speakers
Black IP trim finisher
Carpeted floor & cargo area
Driver & front passenger map pockets
Dual front & rear cup holders
Fasten seat belt warning light/chime
Front & rear passenger folding assist grips
Immobilizer system
Pwr rear trunk release
Rear parcel shelf
Rear window defroster w/timer
Reclining front bucket seats w/active adjustable headrests
Remote fuel lid release
Roof mounted antenna
Tachometer
Tilt steering column
Woven cloth seat trim
Mechanical
1.6L DOHC 16-valve SMPFI I4 engine
5-speed manual transmission w/OD
Battery saver
Electric speed-sensitive variable-assist pwr steering
Electronically controlled drive-by-wire throttle
Front wheel drive
Independent strut front suspension w/stabilizer bar
Pwr front vented disc/rear drum brakes
Torsion beam rear suspension w/stabilizer bar
Safety
3-point ELR driver seat belt w/pretensioner & load limiter
3-point ELR/ALR front passenger seat belt w/pretensioner & load limiter
3-point ELR/ALR rear seat belts at all positions
Child safety rear door locks
Clutch interlock
Dual-stage front airbags w/occupant classification system
Energy absorbing front/rear bumpers
Energy absorbing steering column
Front & rear side curtain airbags
Front side-impact airbags
Rear child seat tether anchors (LATCH)
Slide-away brake pedal assembly
Steel side-door impact beams
Tire pressure monitoring system (TPMS)
Zone body construction w/front/rear crumple zones, hood deformation point
Brake Type: Pwr
Disc - Front (Yes or ): Yes
Drum - Rear (Yes or ): Yes
Front Brake Rotor Diam x Thickness (in): 11.02 x 0.95
Rear Drum Diam x Width (in): 9.0 x
Cargo Area Dimensions
Trunk Volume (ft�: 13.8
Cooling System
Total Cooling System Capacity (qts): 7.2
Electrical
Cold Cranking Amps @ 0� F (Primary): 470
Maximum Alternator Capacity (amps): 110
Engine
Displacement: 1.6L/
Engine Type: Gas 4-Cyl
Fuel System: SMPI
SAE Net Horsepower @ RPM: 107 @ 6000
SAE Net Torque @ RPM: 111 @ 4600
Exterior Dimensions
Height, Overall (in): 60.4
Length, Overall (in): 176.0
Liftover Height (in): 27.8
Min Ground Clearance (in): 6.3
Tread Width, Front (in): 58.3
Tread Width, Rear (in): 58.5
Wheelbase (in): 102.4
Width, Max w/o mirrors (in): 66.7
Fuel Tank
Fuel Tank Capacity, Approx (gal): 13.2
Interior Dimensions
Front Head Room (in): 40.6
Front Hip Room (in): 48.8
Front Leg Room (in): 41.4
Front Shoulder Room (in): 53.5
Passenger Capacity: 5
Passenger Volume (ft�: 94.3
Second Head Room (in): 37.9
Second Hip Room (in): 47.2
Second Leg Room (in): 38.0
Second Shoulder Room (in): 50.7
Mileage
EPA Fuel Economy Est - City (MPG): 26 (Est)
EPA Fuel Economy Est - Hwy (MPG): 34 (Est)
Fuel Economy Est-Combined (MPG): 28
Steering
Lock to Lock Turns (Steering): 3.25
Steering Ratio (:1), Overall: 18.3
Steering Type: Pwr
Turning Diameter - Curb to Curb (ft): 34.2
Summary
Body Style: 4 Door Sedan
Vehicle Name: Versa
Suspension
Stabilizer Bar Diameter - Front (in): 0.91
Stabilizer Bar Diameter - Rear (in): 0.87
Suspension Type - Front: Independent Strut
Suspension Type - Front (Cont.): w/Stabilizer bar
Suspension Type - Rear: Torsion beam
Suspension Type - Rear (Cont.): w/Stabilizer bar
Tires
Front Tire Size: P185/65R14
Rear Tire Size: P185/65R14
Spare Tire Size: T125/70D15
Transmission
Drivetrain: Front Wheel Drive
Fifth Gear Ratio (:1): 0.89
First Gear Ratio (:1): 3.73
Fourth Gear Ratio (:1): 1.03
Second Gear Ratio (:1): 2.05
Third Gear Ratio (:1): 1.39
Trans Description Cont.: Manual
Trans Type: 5
Vehicle
EPA Classification: Compact
EPA Greenhouse Gas Score: 8
Weight Information
Base Curb Weight (lbs): 2516
Wheels
Front Wheel Material: Steel
Front Wheel Size (in): 14 x 5.0
Rear Wheel Material: Steel
Rear Wheel Size (in): 14 x 5.0
Spare Wheel Material: Steel
Spare Wheel Size (in): 15 x
http://www.nissanchantilly.com/ou/ch...ernet_specials
Enjoy!!
Link
No AC, PW, PDL
Manual (5 Speed)
CHANTILLY VA 20151
Warranty
Basic
Powertrain
Black bumpers
Black door handles
Black grille
Compact spare tire
Interior
12V pwr outlet
Immobilizer system
Rear parcel shelf
Tachometer
Mechanical
Battery saver
Front wheel drive
Safety
Clutch interlock
Brake Type: Pwr
Cooling System
Electrical
Engine
Displacement: 1.6L/
Fuel System: SMPI
Exterior Dimensions
Fuel Tank
Interior Dimensions
Mileage
Steering
Steering Type: Pwr
Summary
Vehicle Name: Versa
Suspension
Tires
Transmission
Trans Type: 5
Vehicle
Weight Information
Wheels
Enjoy!!
aliga
16
05-08-14 09:25 AM
GringoEJS
SC400 / 300 Classifieds
01-13-10 06:11 AM
projectsle
09-04-09 09:57 PM
