hks afr type L
hks afr type L
i got this hks afr fuel regulator and damn, this unit really works. i cut the signal wire that comes from air flow meter that goes to the ecu and bypass it with this unit. here's more infos below. i will post some pics later on...
The HKS AFR (Air Fuel Ratio Regulator) is a simple fuel adjusting device that adjusts the air / fuel ratio by changing the airflow voltage output to the factory computer. The AFR was designed for vehicles that are lightly tuned (air cleaner, exhaust system, header, etc), and that only need slight fuel-adjustment. The 10 setting adjustment indicator allows the user to richen or lean the stock setting by approximately 1.0 A/R point in either direction (richer or leaner). Each notch on the adjustment indicator will adjust the A/R by approximately 0.20 of an A/R point. Both the lean side and the rich side have 5 adjustments.
here are the pics. since i can show you how i cut the signal wire from the ecu, i just took pics when it
was done. i decided to just mount it on glove compartment door.
as you can see, the aft unit is used but it works well. heck, if it didnt, i dont think the car would idle right since cutting the signal wire from air flow meter to the ecu plays a big role.....
here you can adjust the **** with small flat head screwdriver for rich or lean ............. when i do this, i can tell from my air/fuel ratio meter right away for lean or rich reading......on idle or full throttle...
