What is the diameter of our stock piping?
O.C. Lucky Strike Fanatic
I plan on doing a straight pipe to my exhausts either with or without resonators. What would you guys recomend the new diameter of the pipes be? Also what is the stock diameter of the piping?
Thanks
Bryan
Thanks
Bryan
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
brian:
do a 2 1/4 piping from cat back......i might chnge mine though to 2.5 like john said....
if u take off yr resonators........good luck and dont get pulled over!!!....trust me, after a while, it will annoy you.
Originally posted by indypwr
brian:
brian:
true that on the annoying noise. also make sure you use mandrel bent pipes...max size should be 2.5"...don't forget your ear plugs
ummagawd
Performance & Maintenance
01-29-04 11:59 AM
