First Gen GS lighting FAQ's
Old 03-18-04 | 06:30 PM
Jmai22's Avatar
Jmai22
Default First Gen GS lighting FAQ's
we need to make this a sticky. Feel free to add info.
Low beam 9006
High beam 9005
Fog light H3
Front turn Signal Orange 1157
Rear turn signal Clear 1156
Rear break lights Clear 1157
Map light?
Dome light?
Door light?
Footwell light?
Trunk light?
i need to find out the footwell light so that i can order some LED's to brighten the interior up. one side of mine is burnt out.
Old 03-18-04 | 07:17 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Default Re: First Gen GS lighting FAQ's
Low beam 9006
High beam 9005
Fog light H3
Map light?
Dome light?
Door light?
Footwell light?
Trunk light?
Footwell bulb is #74, just like it is for most (all?) the other models.
Door (courtesy) and trunk lights are #194.
Dome light is DE3175.
Map light is DE3021
Old 03-18-04 | 08:57 PM
Jmai22's Avatar
Jmai22
sweet, THANKS.
Old 03-18-04 | 10:37 PM
Jmai22's Avatar
Jmai22
do you know what size the bulb is in the back seat in the pillar is when you open the rear doors?
Old 03-19-04 | 12:01 AM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
I'm not 100% sure on this, but if it's like the configuration as my 1st gen LS, then it should be the same as the map light bulb....so, DE3021. If you could get the bulb out and take a pic of it, I could tell you.
Old 03-19-04 | 12:42 AM
Jmai22's Avatar
Jmai22
DE3021=??? is that 194
Old 03-19-04 | 01:58 AM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Edit: Nevermind....I just read in your other post that you're looking for the light that goes on when you open the door...I thought you were talking about the map lights.
The light that you're talking about IS a 194 bulb...sorry for the confusion.
Old 03-19-04 | 06:39 AM
C to the O's Avatar
C to the O
Hope this helps.. this listing is for a '96, but I don't expect that there would be much of a diff w/ the different model years...
http://www.sylvania.com/bin/carApp/c...GS300&x=35&y=3
Old 03-19-04 | 11:56 AM
Jmai22's Avatar
Jmai22
Ok i just got my lazy self up and went out and took out all the bulbs to find out what they are.
Front dome=3022 31mm length type
Rear map lights are also same type of bulb 3022, they are just run on lower wattage but they are the exact same type.
Footwell and glove box are both #74
as for the front map light i can't figure out what they are. it looks like a mini 1156/1157 bulb
Old 10-01-08 | 06:19 AM
bguild's Avatar
bguild
Can someone update this with a wiring diagram for 1GS headlights?
What I am trying to figure out is which wire gets +12v on the 9005 connector when the high beams are actuated. I will use this +12v as input on my aftermarket BiXenon HID harness to trigger the high beam.
Thoughts?
Old 10-04-08 | 07:47 PM
1stGS30's Avatar
1stGS30
now where can one find the L.E.D's to replace the old bulbs?
Old 10-05-08 | 10:27 AM
Temptation's Avatar
Temptation
You can try V-LEDS.com website to order your replacements. I've also heard that other CL members ordered their leds from an oversea vendor on Ebay(forgot the name though !) Good lucks !!
Old 10-10-08 | 12:01 PM
tim8oland's Avatar
tim8oland
Does anyone know if the JDM Aristo Fog Lights use H3 bulbs like the GS300??
Low beam 9006
High beam 9005
Fog light H3
Map light?
Dome light?
Door light?
Footwell light?
Trunk light?
Old 10-10-08 | 02:58 PM
jmax.garage's Avatar
jmax.garage
yes they do
Old 10-10-08 | 06:44 PM
deknick's Avatar
deknick
i have enough bulbs still left over to make a couple kits, i can probally include enough bulbs to do every single interior bulb in the car and trunk, license plate.
