here is the stereo wiring diagram for our cars
Originally posted by Pianoman72
Jmai I think you want to cross the RED-GREEN that you circled with the BLACK-YELLOW wire. That should give the antenna power and then you can use the ANT output from your aftermarket headunit and connect it to the BLACK-WHITE wire (pin 9) up behind the headunit. Total longshot.
You could try both pins 4 and 10 together? Where did you find that post anyway where the SC guys were talking about what wires make the antenna go up. I have both diagrams; it's back to the drawing board but I can't find that post....
Also, both the BLUE-YELLOW and the BLACK-YELLOW wires going into the antenna are labeled +B. WTF is up with that.
Maybe crossing the wires back at the antenna was a bad idea on my part. If we are supposed to trigger some stupid "antenna relay" and we don't know where it is, we should probably stick to the wires behind the HU.
That deal that is not connected is probably that "telephone transceiver" thing.
OK if you are just joining us, HELP. lol.
FACT 1:
We have three wires:
ANTA ------ BLACK-YELLOW
ANT+B----- BLACK-WHITE
ANTB ------ BLACK-ORANGE
FACT 2:
We need to trigger a relay
SOMETHING THAT MIGHT BE TRUE:
The SC guys reportedly used the "AMP" wire somehow (RED-GREEN).
SOMETHING THAT IS MOST DEFINITELY TRUE:
Jmai's antenna has not moved for two years.
There now everyone is up to speed.
FACT 1:
FACT 2:
https://www.clublexus.com/forums/sho...hlight=antenna
here's one of the link. there's a few more let me dig more. you sound like you knew what you were talkinb about here htough .lol.
OK this is what HE did in that thread so I'm taking it for OUR CARS but our diagram is labeled differently.
1) Take the ANT lead from your aftermarket headunit.
2) Connect it to freaking pin #3 RED-GREEN ***AND***
guess 1 --- pin #9 BLACK-WHITE (ANT+B)
guess 2 --- pin #4 BLACK-YELLOW (ANTA)
guess 3 --- pin#10 freaking BLACK-ORANGE
Don't mess around in the trunk do this behind the HU.
3) Pour coke on antenna
4) hit with hammer
4) hit with hammer
Already? Dammit. That makes no sense. I thought for sure we would get it working. Oh well the diagram is on here. Sorry, man.
Originally posted by Jmai22
i tried connecting the amp wire pin3 with each of the anteanna wire and still no go.
I have already purchased a head unit that has CD-changer capability. And am waiting on a changer.
The only "Cable" I should need is the interface cable that provides signal and power from the deck to the changer. Unfortunately that is part of the main wiring harness and will have to be custom made, I am waiting on the maker.
Ken
Ken
What's the going rate for a 1st gen GS radio with the cd button? I've never seen one for sale on CL. Yeah probably want to make your own cable for the changer. METRA might make a plug that fits or you could source one from a different Toyota model. Hopefully Toyota CD changer cables don't vary that much. I remember some guy with an LS did make his own cable and I think he had an aftermarket changer, too.
for my aftermarket head unit i just connected all three wires that were on the stock headunit to the "pwr antenna" lead on my headunit and it works fine.... Btw decent job on the sound deadening hehe, but i've got 200 ft^2 in the lex too The roof was a hardest to do me thinks....
Gompka, do you remember if it was pin 4, 9, 10 that you used? i'll try again tomorow with some better wires.
Ken
