here is the stereo wiring diagram for our cars
#31
Originally posted by Jmai22
ROOF? you crazy guy. i used about 3 cans of expanding foam in my trunk, trunk lid, and rear deck, also about 150 or so sqft in my trunk and rear door. and entire back seat.
Gompka, do you remember if it was pin 4, 9, 10 that you used? i'll try again tomorow with some better wires.
#32
Guys, I understand that the Toyota Amplifier Interface (Metra # 70-8112) is the part used to connect to connector R2 in the diagram. But then, what is the purpose of connector R3 which is Blue in color? Metra does not seem to sell a plug corresponding to this connector.
Thanks,
Brian
Thanks,
Brian
#33
I added a bunch of photos and info about 70-8112 to the aftermarket stereo faq here
https://www.clublexus.com/forums/sho...t=89612&page=3
Still trying to figure out how to make the factory antenna go up with the antenna lead on my aftermarket deck. Did you guys ever figure that out ?
Thanks,
Brian
Thanks,
Brian
#34
Guys, finally figured it out. Funny that I couldn't find this info anywhere by searching, and also found a lot of mis-information about other wire colors.
On a 1993 (and probably all the way to 1997) GS300 w/ Pioneer, you attach the ANTENNA lead from the aftermarket deck to the BLACK W/ WHITE STRIPE wire in the Blue OEM 10 pin connector. Antenna goes up with radio, and down when headunit is off or in CD or AUX mode.
Also, you will see two antenna leads back there. You only need to hook up the larger one to your aftermarket deck. Tape up the smaller one and stuff it in back. The smaller one is called a diversity antenna, and was Lexus' attempt to get better reception. This is why your antenna normally goes up and down depending on what station you tune to on the stock deck.
If you have ALTERNATOR WHINE you can either use RCA GROUND LOOP ISOLATORS (radio shack), or you can ground all of the individual speakers to the cars frame, or a common ground. I've been told the GROUP LOOP ISOLATOR route, which I used, negatively affects sound quality. But, heck, I can't tell the difference...
Good luck...
Brian
Good luck...
Brian
#35
My friend has a 1994 gs300 and he recently just had a cd player put in that he did himself.....now everytime he turns on his car he has to reprogram his car clock and his radio clock. It never stays programmed.....any suggestions guys?
peekay64
02-25-07 10:49 AM
nthach
01-27-05 11:32 PM
