Air Intake Systems
O.C. Lucky Strike Fanatic
Originally posted by binelus
What company makes good air intake systems for our GSs ?
-Bryan
Originally posted by BRAKATK
Blitz LM is another filter and adapter for Gen I. No pipe on that kit though.
It's a modified civic pipe. Here's a pic of the intake pipe I used to have. It's yours for 20.00+shipping. All you have to do is connect it to the airbox and your all set. This will save you the 1-2 hours it took me to cut it...
Thanks! Did you go back to stock? Can I use the factory connectors or do I need to find some (like your blue ones?). Does the pipe make as big a diff to performance as the filter does? Seems like you could fit a much longer conical filter in the airbay...Have to go measure I guess...
I went to just the cone filter as I also have exhausts. Since I just have axle back exhausts, I felt too much air was going into my car and since I have axle back exhausts, the air can not come out quick enough. It would be perfect for you since you dont have a cone filter so you can just attach it on there.
Bryan
ive heard that getting an intake can screw with your stock computer..... i actually just got a K&L drop in air filter. its a reausable one that i bought for about 60 bucks. it improves airflow without any cutting, or new parts. its just a simple drop in and i think it works
