Vibration/Noise from Hood
Someone please help.... i cant find out whats wrong with my car. I have had this problem for a while and its gotten worse since..... when i hit the gas, my car sounds fine but when i am going 30mph+ theres a rattle and a little vibration from my hood area. i dont know what this is..... some thought it was the catalitic converter cover but i need to know how to fix this..... its driving me crazy!!!! more than the wind noise!!!!!! ahhhh someone help!
As it usually turns out with my car, serious problem turns out to be so trivial and easy....of course I can't tell if that's exactly the same problem as with my GS300, but it might be...I used to have the same kind of sound and used to think it was coming from the hood ,,but,,when I listened to it,,,it turned out to be the exhaust pipe (silencer) that produced that sound...check it and make sure it doesn't vibrate..nothing serious...when you open the hood or when the engine is idling you don't hear that sound...but when you accelerate (when rpm are 2500-4000) that's when you hear that sound....Anyway check the silencer (exhaust pipe)
thanks for the help.... it might sound dumb but i was wondering if there was a certain part of the pipe i had to look at. where did you find the problem in yours? it does seem to me like the drive is a little rougher but that might be because i need a wheel reallignment. oh well. im having it checked out today or tommorow
thanks again
thanks again
